2017-03-03 08:00 AM - last edited on 2023-05-24 10:01 AM by Rubia Torres
2017-03-03 08:16 AM
2017-03-03 09:00 AM
Barry wrote:Found the issue!
Have a look in the settings for you plan view and see what MVO scheme it is using.
Maybe it is using a scheme that has different detail settings.
Just changing the MVO may change what you see on screen but as soon as you use one of the views it will revert back to what was saved with that view.
So you either need to modify the MVO scheme ('Store As' and overwrite an existing scheme) which will affect all views using that scheme or set your view to use a different MVO scheme that has the settings you want.
