Modelling Gabion (steel mesh)
Hi guys,
Do we have any solution to model the gabion box which can be adjusted the size without changing the scale of it?
For example in my attached image, I just model the object with slab and column or morph and then convert it into an object. The ideal situation is that there is a flexibility in parameter to change the size of the steel mesh.
it would be perfect if you guys can help me or suggest the solution.
Thanks
Nader Belal
Mentor
3 solutions: [list=]
  • Either you script it
  • [list=]
  • Either you remodel it
  • [list=]
  • Either you use ArchiCAD - Grasshopper live link to make the different gabion sizes without modifying its scale
  • A good friend of mine have once told me that IĀ“m so brute that IĀ“m capable of creating a GDL script capable of creating GDLs.
    Aaron Bourgoin
    you mean like this?
    https://bimcomponents.com/GSM/Details/19273
    Think Like a Spec Writer
    MacBook M4Pro
    AC4.55 through 29 / AC29.0.2 USA
    Rhino 8.26 Mac
    MacOS Tahoe 26.2
    Lingwisyer
    Guru
    I would have been tempted to just model it as two boxes with the exterior one having an alpha that matches the desired grid.
    Ling.
