Modifying 2D symbol stretches 3D
I am trying to modify an objects 2D symbol. The object was created by opening an IFC file which was exported from Revit. I am trying to paste a 2D drawing into the 2D symbol window. The problem is the 2D symbol is larger then the 3D so it ends up stretching the 3D to the same size as the 2D symbol. Is there anyway to have them be different dimensions? Thanks
5 Replies 5
Hello,
I think the object has as default a setting to take it's dimensions A and B
from the 2D symbol. In addition translators usually write in the beginning of
the 3D-program a line;
mul A/xxxxx, B/yyyyy, ZZYZX/zzzzz
That line scales your 3D model according the 2D symbol size. To prevent
the scaling just fix the line to;
mul 1, 1, 1
Hope this works.
I used the find and replace and changed it all to mul 1,1,1 and it's still stretching it, but only in the x axis. In the attached image you can see the correctly sized object on the right and the streched one on the left. The nodes of the left object represent the extent of the 2D symbol of that object
Hello,
Could you kindly post the object or the 3D code?
Juha,
Here is the 3D script. Thanks for taking the time to help.
! 3D SCRIPT (Generated by ArchiCAD IFC_2x3 extension)
! DocName:IFCBUILDINGELEMENTPROXY
MATERIAL gs_fill_mat
! Begin (Body:1)
mul 1, 1, 1
XFORM T11, T12, T13, T14,
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324009952663129, 0.015151515151514, 0.880768285983291 !#1
VERT 0.299116771453052, 0.015151515151514, 0.881640608282472 !#2
VERT 0.324281634561326, 0.015151515151514, 0.882434681554768 !#3
VERT 0.324540903134838, 0.015151515151514, 0.884323276668065 !#4
VERT 0.324752551085140, 0.015151515151514, 0.886234081023380 !#5
VERT 0.299907831011938, 0.015151515151514, 0.887098585241345 !#6
VERT 0.324895747847463, 0.015151515151514, 0.887887075002012 !#7
VERT 0.325018573923049, 0.015151515151514, 0.889844696427237 !#8
VERT 0.325091765900844, 0.015151515151514, 0.891811645963519 !#9
VERT 0.300789053502124, 0.015151515151514, 0.892664074501080 !#10
VERT 0.325114632077529, 0.015151515151514, 0.893431664282784 !#11
VERT 0.325098162992514, 0.015151515151514, 0.895350290636737 !#12
VERT 0.325034519082350, 0.015151515151514, 0.897265207428959 !#13
VERT 0.301654459239682, 0.015151515151514, 0.898097079694137 !#14
VERT 0.324947064843413, 0.015151515151514, 0.898832074177218 !#15
VERT 0.324789101170617, 0.015151515151514, 0.900825331390021 !#16
VERT 0.324579810078414, 0.015151515151514, 0.902800716130215 !#17
VERT 0.302575176324362, 0.015151515151514, 0.903601944538032 !#18
VERT 0.324386291606265, 0.015151515151514, 0.904290190828498 !#19
VERT 0.324080689910795, 0.015151515151514, 0.906264945255439 !#20
VERT 0.323723300331578, 0.015151515151514, 0.908206712506752 !#21
VERT 0.303478203879740, 0.015151515151514, 0.908968739236953 !#22
VERT 0.323430704151032, 0.015151515151514, 0.909598337224940 !#23
VERT 0.320747433879162, 0.015151515151514, 0.918409657380815 !#24
VERT 0.317004261253958, 0.015151515151514, 0.925621418949306 !#25
VERT 0.312443711506481, 0.015151515151514, 0.930766362117446 !#26
VERT 0.307361268840110, 0.015151515151514, 0.933511139039547 !#27
VERT 0.302086231608258, 0.015151515151514, 0.933677911896227 !#28
VERT 0.296960376627440, 0.015151515151514, 0.931255875247915 !#29
VERT 0.292315814993798, 0.015151515151514, 0.926401956133940 !#30
VERT 0.288453474154758, 0.015151515151514, 0.919430646556819 !#31
VERT 0.285623600411578, 0.015151515151514, 0.910793627118885 !#32
VERT 0.284009545122091, 0.015151515151514, 0.901050502023471 !#33
VERT 0.313727740641563, 0.015151515151514, 0.901802482854203 !#34
VERT 0.313364065494274, 0.015151515151514, 0.899558914871378 !#35
VERT 0.283965653533270, 0.015151515151514, 0.900575351540491 !#36
VERT 0.283783229729911, 0.015151515151514, 0.898058636881810 !#37
VERT 0.283683142799853, 0.015151515151514, 0.895524592868254 !#38
VERT 0.312830948989872, 0.015151515151514, 0.896270037065703 !#39
VERT 0.312467273842583, 0.015151515151514, 0.894026469082878 !#40
VERT 0.283672564698434, 0.015151515151514, 0.894987235177652 !#41
VERT 0.283671956336023, 0.015151515151514, 0.892494449191584 !#42
VERT 0.283750988342575, 0.015151515151514, 0.890006381512459 !#43
VERT 0.311957632624685, 0.015151515151514, 0.890882413934404 !#44
VERT 0.311593957477396, 0.015151515151514, 0.888638845951579 !#45
VERT 0.283775829872815, 0.015151515151514, 0.889519401243295 !#46
VERT 0.283954471291130, 0.015151515151514, 0.886994873054822 !#47
VERT 0.284215198310808, 0.015151515151514, 0.884497367389309 !#48
VERT 0.311093136254276, 0.015151515151514, 0.885360417237358 !#49
VERT 0.310729461106988, 0.015151515151514, 0.883116849254533 !#50
VERT 0.284271725017757, 0.015151515151514, 0.884043997656407 !#51
VERT 0.284629817728498, 0.015151515151514, 0.881581385761365 !#52
VERT 0.285067938786868, 0.015151515151514, 0.879167945527894 !#53
VERT 0.310160221178548, 0.015151515151514, 0.880033784075936 !#54
VERT 0.309796546031259, 0.015151515151514, 0.877790216093111 !#55
VERT 0.285180803567914, 0.015151515151514, 0.878616262026718 !#56
VERT 0.285749567777566, 0.015151515151514, 0.876138420653836 !#57
VERT 0.286403164866950, 0.015151515151514, 0.873740607015478 !#58
VERT 0.309274615019090, 0.015151515151514, 0.874483683521793 !#59
VERT 0.308910939871802, 0.015151515151514, 0.872240115538968 !#60
VERT 0.286561949561769, 0.015151515151514, 0.873212168837816 !#61
VERT 0.287406226194045, 0.015151515151514, 0.870673411655926 !#62
VERT 0.288346396633440, 0.015151515151514, 0.868264800120031 !#63
VERT 0.308408862163109, 0.015151515151514, 0.869083081221985 !#64
VERT 0.308045187015820, 0.015151515151514, 0.866839513239161 !#65
VERT 0.288580686161481, 0.015151515151514, 0.867719155137200 !#66
VERT 0.292127562722735, 0.015151515151514, 0.861306477840991 !#67
VERT 0.296345431776105, 0.015151515151514, 0.856667729766007 !#68
VERT 0.301003470473629, 0.015151515151514, 0.854056766361078 !#69
VERT 0.305846767687322, 0.015151515151514, 0.853616472576266 !#70
VERT 0.310610274018485, 0.015151515151514, 0.855370943485186 !#71
VERT 0.315033306623783, 0.015151515151514, 0.859224165682317 !#72
VERT 0.318873815081625, 0.015151515151514, 0.864965271615792 !#73
VERT 0.321921627599419, 0.015151515151514, 0.872280079312381 !#74
VECT 0.000000000000000, -1.000000000000000, 0.000000000000000 !#1
EDGE 1, 2, 1, -1, 0 !#1
EDGE 2, 3, 1, -1, 0 !#2
EDGE 3, 4, 1, -1, 0 !#3
EDGE 4, 5, 1, -1, 0 !#4
EDGE 5, 6, 1, -1, 0 !#5
EDGE 6, 7, 1, -1, 0 !#6
EDGE 7, 8, 1, -1, 0 !#7
EDGE 8, 9, 1, -1, 0 !#8
EDGE 9, 10, 1, -1, 0 !#9
EDGE 10, 11, 1, -1, 0 !#10
EDGE 11, 12, 1, -1, 0 !#11
EDGE 12, 13, 1, -1, 0 !#12
EDGE 13, 14, 1, -1, 0 !#13
EDGE 14, 15, 1, -1, 0 !#14
EDGE 15, 16, 1, -1, 0 !#15
EDGE 16, 17, 1, -1, 0 !#16
EDGE 17, 18, 1, -1, 0 !#17
EDGE 18, 19, 1, -1, 0 !#18
EDGE 19, 20, 1, -1, 0 !#19
EDGE 20, 21, 1, -1, 0 !#20
EDGE 21, 22, 1, -1, 0 !#21
EDGE 22, 23, 1, -1, 0 !#22
EDGE 23, 24, 1, -1, 0 !#23
EDGE 24, 25, 1, -1, 0 !#24
EDGE 25, 26, 1, -1, 0 !#25
EDGE 26, 27, 1, -1, 0 !#26
EDGE 27, 28, 1, -1, 0 !#27
EDGE 28, 29, 1, -1, 0 !#28
EDGE 29, 30, 1, -1, 0 !#29
EDGE 30, 31, 1, -1, 0 !#30
EDGE 31, 32, 1, -1, 0 !#31
EDGE 32, 33, 1, -1, 0 !#32
EDGE 33, 34, 1, -1, 0 !#33
EDGE 34, 35, 1, -1, 0 !#34
EDGE 35, 36, 1, -1, 0 !#35
EDGE 36, 37, 1, -1, 0 !#36
EDGE 37, 38, 1, -1, 0 !#37
EDGE 38, 39, 1, -1, 0 !#38
EDGE 39, 40, 1, -1, 0 !#39
EDGE 40, 41, 1, -1, 0 !#40
EDGE 41, 42, 1, -1, 0 !#41
EDGE 42, 43, 1, -1, 0 !#42
EDGE 43, 44, 1, -1, 0 !#43
EDGE 44, 45, 1, -1, 0 !#44
EDGE 45, 46, 1, -1, 0 !#45
EDGE 46, 47, 1, -1, 0 !#46
EDGE 47, 48, 1, -1, 0 !#47
EDGE 48, 49, 1, -1, 0 !#48
EDGE 49, 50, 1, -1, 0 !#49
EDGE 50, 51, 1, -1, 0 !#50
EDGE 51, 52, 1, -1, 0 !#51
EDGE 52, 53, 1, -1, 0 !#52
EDGE 53, 54, 1, -1, 0 !#53
EDGE 54, 55, 1, -1, 0 !#54
EDGE 55, 56, 1, -1, 0 !#55
EDGE 56, 57, 1, -1, 0 !#56
EDGE 57, 58, 1, -1, 0 !#57
EDGE 58, 59, 1, -1, 0 !#58
EDGE 59, 60, 1, -1, 0 !#59
EDGE 60, 61, 1, -1, 0 !#60
EDGE 61, 62, 1, -1, 0 !#61
EDGE 62, 63, 1, -1, 0 !#62
EDGE 63, 64, 1, -1, 0 !#63
EDGE 64, 65, 1, -1, 0 !#64
EDGE 65, 66, 1, -1, 0 !#65
EDGE 66, 67, 1, -1, 0 !#66
EDGE 67, 68, 1, -1, 0 !#67
EDGE 68, 69, 1, -1, 0 !#68
EDGE 69, 70, 1, -1, 0 !#69
EDGE 70, 71, 1, -1, 0 !#70
EDGE 71, 72, 1, -1, 0 !#71
EDGE 72, 73, 1, -1, 0 !#72
EDGE 73, 74, 1, -1, 0 !#73
EDGE 74, 1, 1, -1, 0 !#74
PGON 74, 1, -1, 20, 21, 22, 23, 24,
25, 26, 27, 28, 29, 30,
31, 32, 33, 34, 35, 36,
37, 38, 39, 40, 41, 42,
43, 44, 45, 46, 47, 48,
49, 50, 51, 52, 53, 54,
55, 56, 57, 58, 59, 60,
61, 62, 63, 64, 65, 66,
67, 68, 69, 70, 71, 72,
73, 74, 1, 2, 3, 4,
5, 6, 7, 8, 9, 10,
11, 12, 13, 14, 15, 16,
17, 18, 19 !#1
BODY 0 !#1
DEL 2
! End (Body:1)
! Begin (Body:2)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.343017698559858, 0.015151515151514, 0.881585761600557 !#1
VERT 0.345937055699920, 0.015151515151514, 0.900376290472348 !#2
VERT 0.349566634084779, 0.015151515151514, 0.900376290472348 !#3
VERT 0.350979933315998, 0.015151515151514, 0.909473032917549 !#4
VERT 0.337565397873877, 0.015151515151514, 0.909473032917549 !#5
VERT 0.336151915729952, 0.015151515151514, 0.900376290472348 !#6
VERT 0.340383466373404, 0.015151515151514, 0.900376290472348 !#7
VERT 0.337464109233342, 0.015151515151514, 0.881585761600557 !#8
EDGE 8, 1, 1, -1, 0 !#8
PGON 8, 1, -1, 3, 4, 5, 6, 7,
8, 1, 2 !#1
BODY 0 !#1
DEL 2
! End (Body:2)
! Begin (Body:3)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.347530111043749, 0.015151515151514, 0.881585761600557 !#1
VERT 0.351862767415030, 0.015151515151514, 0.909473032917549 !#2
VERT 0.359532228561322, 0.015151515151514, 0.909473032917549 !#3
VERT 0.360448684786456, 0.015151515151514, 0.909365699376078 !#4
VERT 0.361330398249763, 0.015151515151514, 0.908869116507180 !#5
VERT 0.362133988190202, 0.015151515151514, 0.908007716446314 !#6
VERT 0.362819917564697, 0.015151515151514, 0.906823880524553 !#7
VERT 0.363354438291222, 0.015151515151514, 0.905375854085049 !#8
VERT 0.363611397025084, 0.015151515151514, 0.903206588413275 !#9
VERT 0.363600633838411, 0.015151515151514, 0.900980891624624 !#10
VERT 0.363322741582984, 0.015151515151514, 0.898821358294964 !#11
VERT 0.362793026963367, 0.015151515151514, 0.896846938621812 !#12
VERT 0.362040667421632, 0.015151515151514, 0.895166386476605 !#13
VERT 0.361342023986662, 0.015151515151514, 0.894090054369701 !#14
VERT 0.360543963401330, 0.015151515151514, 0.893316364916410 !#15
VERT 0.359680800420364, 0.015151515151514, 0.892878584969294 !#16
VERT 0.361093013323241, 0.015151515151514, 0.887228091279313 !#17
VERT 0.367940750859498, 0.015151515151514, 0.909473032917549 !#18
VERT 0.374045335324313, 0.015151515151514, 0.909473032917549 !#19
VERT 0.375323378428032, 0.015151515151514, 0.886502649466101 !#20
VERT 0.378892131250078, 0.015151515151514, 0.909473032917549 !#21
VERT 0.384026323375945, 0.015151515151514, 0.909473032917549 !#22
VERT 0.385905949078704, 0.015151515151514, 0.896345909046666 !#23
VERT 0.387714433811637, 0.015151515151514, 0.909473032917549 !#24
VERT 0.393067797328412, 0.015151515151514, 0.909473032917549 !#25
VERT 0.388735140957130, 0.015151515151514, 0.881585761600557 !#26
VERT 0.383296448870094, 0.015151515151514, 0.881585761600557 !#27
VERT 0.381895769236506, 0.015151515151514, 0.895432876002859 !#28
VERT 0.379744436904380, 0.015151515151514, 0.881585761600557 !#29
VERT 0.370459158827548, 0.015151515151514, 0.881585761600557 !#30
VERT 0.370351801651670, 0.015151515151514, 0.886685493235130 !#31
VERT 0.366351185589120, 0.015151515151514, 0.886685493235130 !#32
VERT 0.365098881596403, 0.015151515151514, 0.881585761600557 !#33
VERT 0.356748286791955, 0.015151515151514, 0.881585761600557 !#34
VERT 0.354708476591192, 0.015151515151514, 0.892973593258396 !#35
VERT 0.352939226354173, 0.015151515151514, 0.881585761600557 !#36
VERT 0.357635397800424, 0.015151515151514, 0.902024431230397 !#37
VERT 0.356226187393292, 0.015151515151514, 0.902024431230399 !#38
VERT 0.355647309236072, 0.015151515151514, 0.898298464791684 !#39
VERT 0.357056519643240, 0.015151515151514, 0.898298464791684 !#40
VERT 0.357523475835710, 0.015151515151514, 0.898379902090424 !#41
VERT 0.357968734180222, 0.015151515151514, 0.898664698919058 !#42
VERT 0.358369078056876, 0.015151515151514, 0.899138005427380 !#43
VERT 0.358513823650163, 0.015151515151514, 0.899553613976933 !#44
VERT 0.358617648746499, 0.015151515151514, 0.900012965880804 !#45
VERT 0.358677163208971, 0.015151515151514, 0.900501062204244 !#46
VERT 0.358690864013136, 0.015151515151514, 0.900771447733283 !#47
VERT 0.358670365802375, 0.015151515151514, 0.901040210862063 !#48
VERT 0.358616891417491, 0.015151515151514, 0.901291318263372 !#49
VERT 0.358533630925197, 0.015151515151514, 0.901509789879684 !#50
VERT 0.358425551311560, 0.015151515151514, 0.901682592573134 !#51
VERT 0.358299100171600, 0.015151515151514, 0.901799417630097 !#52
VERT 0.357973010609085, 0.015151515151514, 0.901975871276989 !#53
VERT 0.370035917921101, 0.015151515151514, 0.901690752459415 !#54
VERT 0.367850953718060, 0.015151515151514, 0.892792967950657 !#55
VERT 0.370223229937669, 0.015151515151514, 0.892792967950657 !#56
VECT 0.000000000000000, 1.000000000000000, 0.000000000000000 !#1
EDGE 36, 1, 1, -1, 0 !#36
EDGE 53, 37, 1, -1, 0 !#53
EDGE 56, 54, 1, -1, 0 !#56
PGON 58, 1, -1, 24, 25, 26, 27, 28,
29, 30, 31, 32, 33, 34,
35, 36, 1, 2, 3, 4,
5, 6, 7, 8, 9, 10,
17, 18, 19, 20, 21, 22,
23,
0, 37, 38, 39, 40, 41,
42, 43, 44, 45, 46, 47,
48, 49, 50, 51, 52, 53,
0, 54, 55, 56 !#1
BODY 0 !#1
DEL 2
! End (Body:3)
! Begin (Body:4)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.400402906520504, 0.015151515151514, 0.881585761600557 !#1
VERT 0.390064988035680, 0.015151515151514, 0.881585761600557 !#2
VERT 0.394397644406961, 0.015151515151514, 0.909473032917549 !#3
VERT 0.404735562891785, 0.015151515151514, 0.909473032917549 !#4
VERT 0.403545319123056, 0.015151515151514, 0.901811993576438 !#5
VERT 0.398367047961095, 0.015151515151514, 0.901811993576438 !#6
VERT 0.397988731073885, 0.015151515151514, 0.899376945704338 !#7
VERT 0.403167002235846, 0.015151515151514, 0.899376945704338 !#8
VERT 0.402029186377449, 0.015151515151514, 0.892053360164016 !#9
VERT 0.396850915215488, 0.015151515151514, 0.892053360164016 !#10
VERT 0.396422225899720, 0.015151515151514, 0.889294088660570 !#11
VERT 0.401600497061682, 0.015151515151514, 0.889294088660570 !#12
EDGE 12, 1, 1, -1, 0 !#12
PGON 12, 1, -1, 1, 2, 3, 4, 5,
6, 7, 8, 9, 10, 11,
12 !#1
BODY 0 !#1
DEL 2
! End (Body:4)
! Begin (Body:5)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324009952663129, 0.020202020202019, 0.880768285983291 !#1
VERT 0.321921627599419, 0.020202020202019, 0.872280079312381 !#2
VERT 0.318873815081625, 0.020202020202019, 0.864965271615792 !#3
VERT 0.315033306623783, 0.020202020202019, 0.859224165682317 !#4
VERT 0.310610274018485, 0.020202020202019, 0.855370943485186 !#5
VERT 0.305846767687322, 0.020202020202019, 0.853616472576266 !#6
VERT 0.301003470473629, 0.020202020202019, 0.854056766361078 !#7
VERT 0.296345431776105, 0.020202020202019, 0.856667729766007 !#8
VERT 0.292127562722735, 0.020202020202019, 0.861306477840991 !#9
VERT 0.288580686161481, 0.020202020202019, 0.867719155137200 !#10
VERT 0.308045187015820, 0.020202020202019, 0.866839513239161 !#11
VERT 0.308408862163109, 0.020202020202019, 0.869083081221985 !#12
VERT 0.288346396633440, 0.020202020202019, 0.868264800120031 !#13
VERT 0.287406226194045, 0.020202020202019, 0.870673411655926 !#14
VERT 0.286561949561769, 0.020202020202019, 0.873212168837816 !#15
VERT 0.308910939871802, 0.020202020202019, 0.872240115538968 !#16
VERT 0.309274615019090, 0.020202020202019, 0.874483683521793 !#17
VERT 0.286403164866950, 0.020202020202019, 0.873740607015478 !#18
VERT 0.285749567777566, 0.020202020202019, 0.876138420653836 !#19
VERT 0.285180803567914, 0.020202020202019, 0.878616262026718 !#20
VERT 0.309796546031259, 0.020202020202019, 0.877790216093111 !#21
VERT 0.310160221178548, 0.020202020202019, 0.880033784075936 !#22
VERT 0.285067938786868, 0.020202020202019, 0.879167945527894 !#23
VERT 0.284629817728498, 0.020202020202019, 0.881581385761365 !#24
VERT 0.284271725017757, 0.020202020202019, 0.884043997656407 !#25
VERT 0.310729461106988, 0.020202020202019, 0.883116849254533 !#26
VERT 0.311093136254276, 0.020202020202019, 0.885360417237358 !#27
VERT 0.284215198310808, 0.020202020202019, 0.884497367389309 !#28
VERT 0.283954471291130, 0.020202020202019, 0.886994873054822 !#29
VERT 0.283775829872815, 0.020202020202019, 0.889519401243295 !#30
VERT 0.311593957477396, 0.020202020202019, 0.888638845951579 !#31
VERT 0.311957632624685, 0.020202020202019, 0.890882413934404 !#32
VERT 0.283750988342575, 0.020202020202019, 0.890006381512459 !#33
VERT 0.283671956336023, 0.020202020202019, 0.892494449191584 !#34
VERT 0.283672564698434, 0.020202020202019, 0.894987235177652 !#35
VERT 0.312467273842583, 0.020202020202019, 0.894026469082878 !#36
VERT 0.312830948989872, 0.020202020202019, 0.896270037065703 !#37
VERT 0.283683142799853, 0.020202020202019, 0.895524592868254 !#38
VERT 0.283783229729911, 0.020202020202019, 0.898058636881810 !#39
VERT 0.283965653533270, 0.020202020202019, 0.900575351540491 !#40
VERT 0.313364065494274, 0.020202020202019, 0.899558914871378 !#41
VERT 0.313727740641563, 0.020202020202019, 0.901802482854203 !#42
VERT 0.284009545122091, 0.020202020202019, 0.901050502023471 !#43
VERT 0.285623600411578, 0.020202020202019, 0.910793627118885 !#44
VERT 0.288453474154758, 0.020202020202019, 0.919430646556819 !#45
VERT 0.292315814993798, 0.020202020202019, 0.926401956133940 !#46
VERT 0.296960376627440, 0.020202020202019, 0.931255875247915 !#47
VERT 0.302086231608258, 0.020202020202019, 0.933677911896227 !#48
VERT 0.307361268840110, 0.020202020202019, 0.933511139039547 !#49
VERT 0.312443711506481, 0.020202020202019, 0.930766362117446 !#50
VERT 0.317004261253958, 0.020202020202019, 0.925621418949306 !#51
VERT 0.320747433879162, 0.020202020202019, 0.918409657380815 !#52
VERT 0.323430704151032, 0.020202020202019, 0.909598337224940 !#53
VERT 0.303478203879740, 0.020202020202019, 0.908968739236953 !#54
VERT 0.323723300331578, 0.020202020202019, 0.908206712506752 !#55
VERT 0.324080689910795, 0.020202020202019, 0.906264945255439 !#56
VERT 0.324386291606265, 0.020202020202019, 0.904290190828498 !#57
VERT 0.302575176324362, 0.020202020202019, 0.903601944538032 !#58
VERT 0.324579810078414, 0.020202020202019, 0.902800716130215 !#59
VERT 0.324789101170617, 0.020202020202019, 0.900825331390021 !#60
VERT 0.324947064843413, 0.020202020202019, 0.898832074177218 !#61
VERT 0.301654459239682, 0.020202020202019, 0.898097079694137 !#62
VERT 0.325034519082350, 0.020202020202019, 0.897265207428959 !#63
VERT 0.325098162992514, 0.020202020202019, 0.895350290636737 !#64
VERT 0.325114632077529, 0.020202020202019, 0.893431664282784 !#65
VERT 0.300789053502124, 0.020202020202019, 0.892664074501080 !#66
VERT 0.325091765900844, 0.020202020202019, 0.891811645963519 !#67
VERT 0.325018573923049, 0.020202020202019, 0.889844696427237 !#68
VERT 0.324895747847463, 0.020202020202019, 0.887887075002012 !#69
VERT 0.299907831011938, 0.020202020202019, 0.887098585241345 !#70
VERT 0.324752551085140, 0.020202020202019, 0.886234081023380 !#71
VERT 0.324540903134838, 0.020202020202019, 0.884323276668065 !#72
VERT 0.324281634561326, 0.020202020202019, 0.882434681554768 !#73
VERT 0.299116771453052, 0.020202020202019, 0.881640608282472 !#74
PGON 74, 1, -1, 53, 54, 55, 56, 57,
58, 59, 60, 61, 62, 63,
64, 65, 66, 67, 68, 69,
70, 71, 72, 73, 74, 1,
2, 3, 4, 5, 6, 7,
8, 9, 10, 11, 12, 13,
14, 15, 16, 17, 18, 19,
20, 21, 22, 23, 24, 25,
26, 27, 28, 29, 30, 31,
32, 33, 34, 35, 36, 37,
38, 39, 40, 41, 42, 43,
44, 45, 46, 47, 48, 49,
50, 51, 52 !#1
BODY 0 !#1
DEL 2
! End (Body:5)
! Begin (Body:6)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.343017698559858, 0.020202020202019, 0.881585761600557 !#1
VERT 0.337464109233342, 0.020202020202019, 0.881585761600557 !#2
VERT 0.340383466373404, 0.020202020202019, 0.900376290472348 !#3
VERT 0.336151915729952, 0.020202020202019, 0.900376290472348 !#4
VERT 0.337565397873877, 0.020202020202019, 0.909473032917549 !#5
VERT 0.350979933315998, 0.020202020202019, 0.909473032917549 !#6
VERT 0.349566634084779, 0.020202020202019, 0.900376290472348 !#7
VERT 0.345937055699920, 0.020202020202019, 0.900376290472348 !#8
PGON 8, 1, -1, 4, 5, 6, 7, 8,
1, 2, 3 !#1
BODY 0 !#1
DEL 2
! End (Body:6)
! Begin (Body:7)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.347530111043749, 0.020202020202019, 0.881585761600557 !#1
VERT 0.351862767415030, 0.020202020202019, 0.909473032917549 !#2
VERT 0.359532228561322, 0.020202020202019, 0.909473032917549 !#3
VERT 0.360448684786456, 0.020202020202019, 0.909365699376078 !#4
VERT 0.361330398249763, 0.020202020202019, 0.908869116507180 !#5
VERT 0.362133988190202, 0.020202020202019, 0.908007716446314 !#6
VERT 0.362819917564697, 0.020202020202019, 0.906823880524553 !#7
VERT 0.363354438291222, 0.020202020202019, 0.905375854085049 !#8
VERT 0.363611397025084, 0.020202020202019, 0.903206588413275 !#9
VERT 0.363600633838411, 0.020202020202019, 0.900980891624624 !#10
VERT 0.363322741582984, 0.020202020202019, 0.898821358294964 !#11
VERT 0.362793026963367, 0.020202020202019, 0.896846938621812 !#12
VERT 0.362040667421632, 0.020202020202019, 0.895166386476605 !#13
VERT 0.361342023986662, 0.020202020202019, 0.894090054369701 !#14
VERT 0.360543963401330, 0.020202020202019, 0.893316364916410 !#15
VERT 0.359680800420364, 0.020202020202019, 0.892878584969294 !#16
VERT 0.361093013323241, 0.020202020202019, 0.887228091279313 !#17
VERT 0.367940750859498, 0.020202020202019, 0.909473032917549 !#18
VERT 0.374045335324313, 0.020202020202019, 0.909473032917549 !#19
VERT 0.375323378428032, 0.020202020202019, 0.886502649466101 !#20
VERT 0.378892131250078, 0.020202020202019, 0.909473032917549 !#21
VERT 0.384026323375945, 0.020202020202019, 0.909473032917549 !#22
VERT 0.385905949078704, 0.020202020202019, 0.896345909046666 !#23
VERT 0.387714433811637, 0.020202020202019, 0.909473032917549 !#24
VERT 0.393067797328412, 0.020202020202019, 0.909473032917549 !#25
VERT 0.388735140957130, 0.020202020202019, 0.881585761600557 !#26
VERT 0.383296448870094, 0.020202020202019, 0.881585761600557 !#27
VERT 0.381895769236506, 0.020202020202019, 0.895432876002859 !#28
VERT 0.379744436904380, 0.020202020202019, 0.881585761600557 !#29
VERT 0.370459158827548, 0.020202020202019, 0.881585761600557 !#30
VERT 0.370351801651670, 0.020202020202019, 0.886685493235130 !#31
VERT 0.366351185589120, 0.020202020202019, 0.886685493235130 !#32
VERT 0.365098881596403, 0.020202020202019, 0.881585761600557 !#33
VERT 0.356748286791955, 0.020202020202019, 0.881585761600557 !#34
VERT 0.354708476591192, 0.020202020202019, 0.892973593258396 !#35
VERT 0.352939226354173, 0.020202020202019, 0.881585761600557 !#36
VERT 0.357635397800424, 0.020202020202019, 0.902024431230397 !#37
VERT 0.356226187393292, 0.020202020202019, 0.902024431230399 !#38
VERT 0.355647309236072, 0.020202020202019, 0.898298464791684 !#39
VERT 0.357056519643240, 0.020202020202019, 0.898298464791684 !#40
VERT 0.357523475835710, 0.020202020202019, 0.898379902090424 !#41
VERT 0.357968734180222, 0.020202020202019, 0.898664698919058 !#42
VERT 0.358369078056876, 0.020202020202019, 0.899138005427380 !#43
VERT 0.358513823650163, 0.020202020202019, 0.899553613976933 !#44
VERT 0.358617648746499, 0.020202020202019, 0.900012965880804 !#45
VERT 0.358677163208971, 0.020202020202019, 0.900501062204244 !#46
VERT 0.358690864013136, 0.020202020202019, 0.900771447733283 !#47
VERT 0.358670365802375, 0.020202020202019, 0.901040210862063 !#48
VERT 0.358616891417491, 0.020202020202019, 0.901291318263372 !#49
VERT 0.358533630925197, 0.020202020202019, 0.901509789879684 !#50
VERT 0.358425551311560, 0.020202020202019, 0.901682592573134 !#51
VERT 0.358299100171600, 0.020202020202019, 0.901799417630097 !#52
VERT 0.357973010609085, 0.020202020202019, 0.901975871276989 !#53
VERT 0.370035917921101, 0.020202020202019, 0.901690752459415 !#54
VERT 0.367850953718060, 0.020202020202019, 0.892792967950657 !#55
VERT 0.370223229937669, 0.020202020202019, 0.892792967950657 !#56
35, 36, 1, 2, 3, 4,
5, 6, 7, 8, 9, 10,
23,
0, 54, 55, 56 !#1
BODY 0 !#1
DEL 2
! End (Body:7)
! Begin (Body:8)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.400402906520504, 0.020202020202019, 0.881585761600557 !#1
VERT 0.390064988035680, 0.020202020202019, 0.881585761600557 !#2
VERT 0.394397644406961, 0.020202020202019, 0.909473032917549 !#3
VERT 0.404735562891785, 0.020202020202019, 0.909473032917549 !#4
VERT 0.403545319123056, 0.020202020202019, 0.901811993576438 !#5
VERT 0.398367047961095, 0.020202020202019, 0.901811993576438 !#6
VERT 0.397988731073885, 0.020202020202019, 0.899376945704338 !#7
VERT 0.403167002235846, 0.020202020202019, 0.899376945704338 !#8
VERT 0.402029186377449, 0.020202020202019, 0.892053360164016 !#9
VERT 0.396850915215488, 0.020202020202019, 0.892053360164016 !#10
VERT 0.396422225899720, 0.020202020202019, 0.889294088660570 !#11
VERT 0.401600497061682, 0.020202020202019, 0.889294088660570 !#12
6, 7, 8, 9, 10, 11,
12 !#1
BODY 0 !#1
DEL 2
! End (Body:8)
! Begin (Body:9)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.299116771453052, 0.015151515151514, 0.881640608282472 !#1
VERT 0.324009952663129, 0.015151515151514, 0.880768285983291 !#2
VERT 0.324009952663129, 0.020202020202019, 0.880768285983291 !#3
VERT 0.299116771453052, 0.020202020202019, 0.881640608282472 !#4
VECT 0.035021124264733, 0.000000000000000, 0.999386572280834 !#1
EDGE 4, 1, 1, -1, 0 !#4
PGON 4, 1, -1, 1, 2, 3, 4 !#1
BODY 0 !#1
DEL 2
! End (Body:9)
! Begin (Body:10)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324281634561326, 0.015151515151514, 0.882434681554768 !#1
VERT 0.299116771453052, 0.020202020202019, 0.881640608282472 !#3
VERT 0.324281634561326, 0.020202020202019, 0.882434681554768 !#4
VECT 0.031539143737622, 0.000000000000000, -0.999502517461711 !#1
BODY 0 !#1
DEL 2
! End (Body:10)
! Begin (Body:11)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324540903134838, 0.020202020202019, 0.884323276668065 !#1
VERT 0.324281634561326, 0.020202020202019, 0.882434681554768 !#2
VECT -0.990708071518661, 0.000000000000000, 0.136005577193642 !#1
BODY 0 !#1
DEL 2
! End (Body:11)
! Begin (Body:12)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324540903134838, 0.015151515151514, 0.884323276668065 !#1
VERT 0.324752551085140, 0.015151515151514, 0.886234081023380 !#2
VERT 0.324752551085140, 0.020202020202019, 0.886234081023380 !#3
VERT 0.324540903134838, 0.020202020202019, 0.884323276668065 !#4
VECT -0.993921564049262, 0.000000000000000, 0.110090528738255 !#1
BODY 0 !#1
DEL 2
! End (Body:12)
! Begin (Body:13)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.299907831011938, 0.015151515151514, 0.887098585241345 !#1
VERT 0.299907831011938, 0.020202020202019, 0.887098585241345 !#4
VECT 0.034775249109374, 0.000000000000000, 0.999395158107833 !#1
BODY 0 !#1
DEL 2
! End (Body:13)
! Begin (Body:14)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324895747847463, 0.015151515151514, 0.887887075002012 !#1
VERT 0.299907831011938, 0.015151515151514, 0.887098585241345 !#2
VERT 0.299907831011938, 0.020202020202019, 0.887098585241345 !#3
VERT 0.324895747847463, 0.020202020202019, 0.887887075002012 !#4
VECT 0.031539143737649, 0.000000000000000, -0.999502517461710 !#1
BODY 0 !#1
DEL 2
! End (Body:14)
! Begin (Body:15)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.325018573923049, 0.020202020202019, 0.889844696427237 !#1
VERT 0.324895747847463, 0.020202020202019, 0.887887075002012 !#2
VERT 0.324895747847463, 0.015151515151514, 0.887887075002012 !#3
VERT 0.325018573923049, 0.015151515151514, 0.889844696427237 !#4
VECT -0.998037481294030, 0.000000000000000, 0.062619373457964 !#1
BODY 0 !#1
DEL 2
! End (Body:15)
! Begin (Body:16)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.325018573923049, 0.015151515151514, 0.889844696427237 !#1
VERT 0.325091765900844, 0.015151515151514, 0.891811645963519 !#2
VERT 0.325091765900844, 0.020202020202019, 0.891811645963519 !#3
VERT 0.325018573923049, 0.020202020202019, 0.889844696427237 !#4
VECT -0.999308392315212, 0.000000000000000, 0.037185172426485 !#1
BODY 0 !#1
DEL 2
! End (Body:16)
! Begin (Body:17)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.300789053502124, 0.020202020202019, 0.892664074501080 !#4
VECT 0.035053891969674, 0.000000000000000, 0.999385423476738 !#1
PGON 4, 1, -1, 2, 3, 4, 1 !#1
BODY 0 !#1
DEL 2
! End (Body:17)
! Begin (Body:18)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.300789053502124, 0.015151515151514, 0.892664074501080 !#2
VERT 0.300789053502124, 0.020202020202019, 0.892664074501080 !#3
VERT 0.325114632077529, 0.020202020202019, 0.893431664282784 !#4
VECT 0.031539143737638, 0.000000000000000, -0.999502517461710 !#1
BODY 0 !#1
DEL 2
! End (Body:18)
! Begin (Body:19)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.325098162992514, 0.020202020202019, 0.895350290636737 !#1
VERT 0.325114632077529, 0.020202020202019, 0.893431664282784 !#2
VERT 0.325114632077529, 0.015151515151514, 0.893431664282784 !#3
VERT 0.325098162992514, 0.015151515151514, 0.895350290636737 !#4
VECT -0.999963161313465, 0.000000000000000, -0.008583473421700 !#1
BODY 0 !#1
DEL 2
! End (Body:19)
! Begin (Body:20)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.325034519082350, 0.015151515151514, 0.897265207428959 !#2
VERT 0.325034519082350, 0.020202020202019, 0.897265207428959 !#3
VERT 0.325098162992514, 0.020202020202019, 0.895350290636737 !#4
VECT -0.999448145890799, 0.000000000000000, -0.033217520609534 !#1
BODY 0 !#1
DEL 2
! End (Body:20)
! Begin (Body:21)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.301654459239682, 0.020202020202019, 0.898097079694137 !#4
VECT 0.035557915984240, 0.000000000000000, 0.999367617351522 !#1
BODY 0 !#1
DEL 2
! End (Body:21)
! Begin (Body:22)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.301654459239682, 0.015151515151514, 0.898097079694137 !#2
VERT 0.301654459239682, 0.020202020202019, 0.898097079694137 !#3
VERT 0.324947064843413, 0.020202020202019, 0.898832074177218 !#4
VECT 0.031539143737641, 0.000000000000000, -0.999502517461710 !#1
BODY 0 !#1
DEL 2
! End (Body:22)
! Begin (Body:23)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324789101170617, 0.020202020202019, 0.900825331390021 !#1
VERT 0.324947064843413, 0.020202020202019, 0.898832074177218 !#2
VERT 0.324947064843413, 0.015151515151514, 0.898832074177218 !#3
VERT 0.324789101170617, 0.015151515151514, 0.900825331390021 !#4
VECT -0.996874511054634, 0.000000000000000, -0.079001324100197 !#1
BODY 0 !#1
DEL 2
! End (Body:23)
! Begin (Body:24)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324579810078414, 0.015151515151514, 0.902800716130215 !#2
VERT 0.324579810078414, 0.020202020202019, 0.902800716130215 !#3
VERT 0.324789101170617, 0.020202020202019, 0.900825331390021 !#4
VECT -0.994434163215927, 0.000000000000000, -0.105359835938747 !#1
BODY 0 !#1
DEL 2
! End (Body:24)
! Begin (Body:25)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.302575176324362, 0.020202020202019, 0.903601944538032 !#4
VECT 0.036387690075907, 0.000000000000000, 0.999337748717089 !#1
BODY 0 !#1
DEL 2
! End (Body:25)
! Begin (Body:26)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324386291606265, 0.020202020202019, 0.904290190828498 !#2
VERT 0.302575176324362, 0.020202020202019, 0.903601944538032 !#3
VERT 0.302575176324362, 0.015151515151514, 0.903601944538032 !#4
VECT -0.031539143737640, 0.000000000000000, 0.999502517461710 !#1
BODY 0 !#1
DEL 2
! End (Body:26)
! Begin (Body:27)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324080689910795, 0.020202020202019, 0.906264945255439 !#1
VERT 0.324386291606265, 0.015151515151514, 0.904290190828498 !#3
VERT 0.324080689910795, 0.015151515151514, 0.906264945255439 !#4
VECT -0.988236433260585, 0.000000000000000, -0.152933815673306 !#1
BODY 0 !#1
DEL 2
! End (Body:27)
! Begin (Body:28)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.324080689910795, 0.015151515151514, 0.906264945255439 !#1
VERT 0.323723300331578, 0.020202020202019, 0.908206712506752 !#3
VERT 0.324080689910795, 0.020202020202019, 0.906264945255439 !#4
VECT -0.983480644725505, 0.000000000000000, -0.181013318433494 !#1
BODY 0 !#1
DEL 2
! End (Body:28)
! Begin (Body:29)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.303478203879740, 0.015151515151514, 0.908968739236953 !#1
VERT 0.303478203879740, 0.020202020202019, 0.908968739236953 !#4
VECT 0.037613428759613, 0.000000000000000, 0.999292364614554 !#1
BODY 0 !#1
DEL 2
! End (Body:29)
! Begin (Body:30)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.323430704151032, 0.015151515151514, 0.909598337224940 !#1
VERT 0.323430704151032, 0.020202020202019, 0.909598337224940 !#2
VERT 0.303478203879740, 0.020202020202019, 0.908968739236953 !#3
VERT 0.303478203879740, 0.015151515151514, 0.908968739236953 !#4
VECT -0.031539143737654, 0.000000000000000, 0.999502517461710 !#1
BODY 0 !#1
DEL 2
! End (Body:30)
! Begin (Body:31)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.320747433879162, 0.020202020202019, 0.918409657380815 !#3
VERT 0.323430704151032, 0.020202020202019, 0.909598337224940 !#4
VECT -0.956626566358655, 0.000000000000000, -0.291317030976307 !#1
BODY 0 !#1
DEL 2
! End (Body:31)
! Begin (Body:32)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.317004261253958, 0.020202020202019, 0.925621418949306 !#1
VERT 0.312443711506481, 0.020202020202019, 0.930766362117446 !#2
VERT 0.312443711506481, 0.015151515151514, 0.930766362117446 !#3
VERT 0.317004261253958, 0.015151515151514, 0.925621418949306 !#4
VECT 0.748328224152060, 0.000000000000000, 0.663328628160600 !#1
BODY 0 !#1
DEL 2
! End (Body:32)
! Begin (Body:33)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.320747433879162, 0.015151515151514, 0.918409657380815 !#1
VERT 0.317004261253958, 0.020202020202019, 0.925621418949306 !#3
VERT 0.320747433879162, 0.020202020202019, 0.918409657380815 !#4
VECT -0.887566325381548, 0.000000000000000, -0.460679951863217 !#1
BODY 0 !#1
DEL 2
! End (Body:33)
! Begin (Body:34)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.312443711506481, 0.020202020202019, 0.930766362117446 !#1
VERT 0.307361268840110, 0.020202020202019, 0.933511139039547 !#2
VERT 0.307361268840110, 0.015151515151514, 0.933511139039547 !#3
VERT 0.312443711506481, 0.015151515151514, 0.930766362117446 !#4
VECT 0.475183480255905, 0.000000000000000, 0.879886731398926 !#1
BODY 0 !#1
DEL 2
! End (Body:34)
! Begin (Body:35)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.302086231608258, 0.015151515151514, 0.933677911896227 !#1
VERT 0.307361268840110, 0.020202020202019, 0.933511139039547 !#3
VECT 0.031599695662646, 0.000000000000000, 0.999500604919291 !#1
BODY 0 !#1
DEL 2
! End (Body:35)
! Begin (Body:36)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.302086231608258, 0.020202020202019, 0.933677911896227 !#1
VERT 0.296960376627440, 0.020202020202019, 0.931255875247915 !#2
VERT 0.296960376627440, 0.015151515151514, 0.931255875247915 !#3
VERT 0.302086231608258, 0.015151515151514, 0.933677911896227 !#4
VECT -0.427221771996353, 0.000000000000000, 0.904146867235792 !#1
BODY 0 !#1
DEL 2
! End (Body:36)
! Begin (Body:37)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.292315814993798, 0.020202020202019, 0.926401956133940 !#1
VERT 0.288453474154758, 0.020202020202019, 0.919430646556819 !#2
VERT 0.292315814993798, 0.015151515151514, 0.926401956133940 !#4
VECT -0.874721795150807, 0.000000000000000, 0.484625402850644 !#1
BODY 0 !#1
DEL 2
! End (Body:37)
! Begin (Body:38)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.296960376627440, 0.020202020202019, 0.931255875247915 !#1
VERT 0.292315814993798, 0.020202020202019, 0.926401956133940 !#2
VERT 0.296960376627440, 0.015151515151514, 0.931255875247915 !#4
VECT -0.722516748380568, 0.000000000000000, 0.691353417804216 !#1
BODY 0 !#1
DEL 2
! End (Body:38)
! Begin (Body:39)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.288453474154758, 0.020202020202019, 0.919430646556819 !#1
VERT 0.285623600411578, 0.020202020202019, 0.910793627118885 !#2
VERT 0.288453474154758, 0.015151515151514, 0.919430646556819 !#4
VECT -0.950292578830013, 0.000000000000000, 0.311358337965443 !#1
BODY 0 !#1
DEL 2
! End (Body:39)
! Begin (Body:40)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.284009545122091, 0.015151515151514, 0.901050502023471 !#1
VERT 0.285623600411578, 0.015151515151514, 0.910793627118885 !#2
VERT 0.285623600411578, 0.020202020202019, 0.910793627118885 !#3
VECT -0.986554348915064, 0.000000000000000, 0.163433523601415 !#1
BODY 0 !#1
DEL 2
! End (Body:40)
! Begin (Body:41)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.313727740641563, 0.015151515151514, 0.901802482854203 !#1
VERT 0.313727740641563, 0.020202020202019, 0.901802482854203 !#2
VERT 0.284009545122091, 0.020202020202019, 0.901050502023471 !#3
VERT 0.284009545122091, 0.015151515151514, 0.901050502023471 !#4
VECT -0.025295620904770, 0.000000000000000, 0.999680014586188 !#1
BODY 0 !#1
DEL 2
! End (Body:41)
! Begin (Body:42)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.313364065494274, 0.015151515151514, 0.899558914871378 !#1
VERT 0.313364065494274, 0.020202020202019, 0.899558914871378 !#2
VERT 0.313727740641563, 0.020202020202019, 0.901802482854203 !#3
VERT 0.313727740641563, 0.015151515151514, 0.901802482854203 !#4
VECT 0.987115673376885, 0.000000000000000, -0.160008272828937 !#1
BODY 0 !#1
DEL 2
! End (Body:42)
! Begin (Body:43)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.283965653533270, 0.015151515151514, 0.900575351540491 !#1
VERT 0.313364065494274, 0.015151515151514, 0.899558914871378 !#2
VERT 0.313364065494274, 0.020202020202019, 0.899558914871378 !#3
VECT 0.034553896682589, 0.000000000000000, 0.999402835809489 !#1
BODY 0 !#1
DEL 2
! End (Body:43)
! Begin (Body:44)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.283783229729911, 0.015151515151514, 0.898058636881810 !#1
VERT 0.283965653533270, 0.015151515151514, 0.900575351540491 !#2
VERT 0.283965653533270, 0.020202020202019, 0.900575351540491 !#3
VERT 0.283783229729911, 0.020202020202019, 0.898058636881810 !#4
VECT -0.997383276651586, 0.000000000000000, 0.072295224294181 !#1
BODY 0 !#1
DEL 2
! End (Body:44)
! Begin (Body:45)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.283783229729911, 0.020202020202019, 0.898058636881810 !#1
VERT 0.283683142799853, 0.020202020202019, 0.895524592868254 !#2
VERT 0.283783229729911, 0.015151515151514, 0.898058636881810 !#4
VECT -0.999220908134637, 0.000000000000000, 0.039466146842478 !#1
BODY 0 !#1
DEL 2
! End (Body:45)
! Begin (Body:46)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.312830948989872, 0.015151515151514, 0.896270037065703 !#1
VERT 0.283683142799853, 0.015151515151514, 0.895524592868254 !#2
VERT 0.312830948989872, 0.020202020202019, 0.896270037065703 !#4
VECT 0.025566264883507, 0.000000000000000, -0.999673129627833 !#1
BODY 0 !#1
DEL 2
! End (Body:46)
! Begin (Body:47)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.312467273842583, 0.015151515151514, 0.894026469082878 !#1
VERT 0.312467273842583, 0.020202020202019, 0.894026469082878 !#2
VERT 0.312830948989872, 0.015151515151514, 0.896270037065703 !#4
VECT 0.987115673376873, 0.000000000000011, -0.160008272829009 !#1
BODY 0 !#1
DEL 2
! End (Body:47)
! Begin (Body:48)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.283672564698434, 0.015151515151514, 0.894987235177652 !#1
VERT 0.312467273842583, 0.015151515151514, 0.894026469082878 !#2
VERT 0.283672564698434, 0.020202020202019, 0.894987235177652 !#4
VECT 0.033347505906159, 0.000000000000000, 0.999443817255297 !#1
BODY 0 !#1
DEL 2
! End (Body:48)
! Begin (Body:49)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.283671956336023, 0.015151515151514, 0.892494449191584 !#1
VERT 0.283672564698434, 0.015151515151514, 0.894987235177652 !#2
VERT 0.283671956336023, 0.020202020202019, 0.892494449191584 !#4
VECT -0.999999970219997, 0.000000000000000, 0.000244049187138 !#1
BODY 0 !#1
DEL 2
! End (Body:49)
! Begin (Body:50)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.283671956336023, 0.020202020202019, 0.892494449191584 !#1
VERT 0.283750988342575, 0.020202020202019, 0.890006381512459 !#2
VERT 0.283750988342575, 0.015151515151514, 0.890006381512459 !#3
VECT -0.999495892511782, 0.000000000000000, -0.031748399204933 !#1
BODY 0 !#1
DEL 2
! End (Body:50)
! Begin (Body:51)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.311957632624685, 0.015151515151514, 0.890882413934404 !#1
VERT 0.283750988342575, 0.015151515151514, 0.890006381512459 !#2
VERT 0.311957632624685, 0.020202020202019, 0.890882413934404 !#4
VECT 0.031042693970746, 0.000000000000000, -0.999518059442169 !#1
BODY 0 !#1
DEL 2
! End (Body:51)
! Begin (Body:52)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.311593957477396, 0.015151515151514, 0.888638845951579 !#1
VERT 0.311593957477396, 0.020202020202019, 0.888638845951579 !#2
VECT 0.987115673376876, 0.000000000000000, -0.160008272828993 !#1
BODY 0 !#1
DEL 2
! End (Body:52)
! Begin (Body:53)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.283775829872815, 0.015151515151514, 0.889519401243295 !#1
VERT 0.311593957477396, 0.015151515151514, 0.888638845951579 !#2
VERT 0.283775829872815, 0.020202020202019, 0.889519401243295 !#4
VECT 0.031638163706556, 0.000000000000000, 0.999499387992448 !#1
BODY 0 !#1
DEL 2
! End (Body:53)
! Begin (Body:54)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.283954471291130, 0.015151515151514, 0.886994873054822 !#1
VERT 0.283775829872815, 0.015151515151514, 0.889519401243295 !#2
VERT 0.283954471291130, 0.020202020202019, 0.886994873054822 !#4
VECT -0.997505711868762, 0.000000000000000, -0.070585797361754 !#1
BODY 0 !#1
DEL 2
! End (Body:54)
! Begin (Body:55)
mul 1, 1, 1
T21, T22, T23, T24,
T31, T32, T33, T34
VERT 0.283954471291130, 0.020202020202019, 0.886994873054822 !#1
VERT 0.284215198310808, 0.015151515151514, 0.884497367389309 !#3
VECT -0.994594984748779, 0.000000000000000, -0.103830709872254 !#1
BODY 0 !#1
DEL 2
! End (Body:55)
! Begin (Body:56)
mul 1, 1, 1
T21, T22,
Hello,
The xform is a transformation matrix command so possibly
is scaling x as well - depending on the values of the T-parameters.
If you comment/erase all the mul, xform and del commands or alternatively
set the xform to;
xform 1,0,0,0,
0,1,0,0,
0,0,1,0,
0,0,0,1
then all the scaling is ignored.
If the object still refuses to behave, then please post
the whole zipped gsm.
Best regards, Juha
