‎2016-03-21
09:25 PM
‎2023-05-24
12:30 PM
Rubia Torres
‎2016-03-22 02:03 PM
‎2016-03-26 11:04 AM
‎2016-03-28 01:41 AM
David wrote:I read this once... and forgot about it. almost removes the need for parametric options... almost. but bravo used it to make pool water a skylight so the client can swim in bimx
Vytautas B:
The custom window method will work, but you need to add a Slab with the ID of "Wallhole" that will define the hole in the Wall (rather than being rectangular). In the Help files see: Elements of the Virtual Building > Parametric Objects > Graphic Creation of Custom Library Parts and Components > Saving Custom-Shape Doors or Windows.
