rengarch
Movable hotspot
Could anyone help. Here is the GDL for a movable hotspot for moving text in an object. Whenever I try to move the hotspot, the text jumps to unexpected locations. Why?
2 parameters are inserted in the parameters window
horz - length parameter, which is the horzontal location of the text
verti - length parameter, which is the vertical location of the text
it almost seems like the coordinates needs to be reset????
Thanks
___________________________GDL
unID=1
!_________________________moving it horizontally
hotspot2 horz,verti,unID,horz,1+128 : unID=unID+1
hotspot2 -1,verti,unID,horz,3 : unID=unID+1
hotspot2 horz,verti,unID,horz,2+256 : unID=unID+1
!_________________________moving it vertically
hotspot2 horz,verti,unID,verti,1+128 : unID=unID+1
hotspot2 horz,-1,unID,verti,3 : unID=unID+1
hotspot2 horz,verti,unID,verti,2+256 : unID=unID+1
define style 'identify' ft,fsize,1,0
set style 'identify'
text2 horz,verti,ID
Rita MF Eng, AIA
iMac 27" 3.5 GHz Intel Core i7
NVIDIA GeForce GTX 780M 4096MB
MAC OSX 10.11.6
Archicad 20
2 Replies 2
Try this:
unID=1
hotspot2 0,verti,unID,horz,1+128 : unID=unID+1
hotspot2 horz,0,unID,verti,1+128 : unID=unID+1
text2 horz,verti,ID
Peter Devlin
rengarch
Thank you so much Peter, that did the trick.
I finally understand how to script this movable hotspot.
The manual is sooooooo cryptic.
Rita MF Eng, AIA
MAC OSX 10.11.6
Archicad 20
