I have several Model View Options pages created however it means that when one opens, the MVO box becomes very large. Is there anyway to collate the multiple MVO objects into 1 object and just have a page selection option like in a regular object?
You can either use the old page navigation bevor AC 18 or you can also put different MVO-Objects into one if you use them in a macro, and then create a parent navigation.
We have this for the German ArchiCARD objects:
More important is to keep as small number of parameters visible per MVO page as possible...otherwise the loading of whole MVO system will slow down.
I did some kind of lock/unlock parameters in my objects that hides the paremeters in MVO page for that reason.
