My Polygons are Degenerates!
I've been on ArchiCAD 10 for weeks. Today none of the windows in "Wood Plastic Windows" works correctly -- they all give me the error:
Polygon is degenerated. at line 910 in the 2D script of file wa_trim_us_10.gsm.
I have restarted ArchiCAD and that didn't solve it. Why would this suddenly start happening? How do I fix it?
5 REPLIES 5
__archiben
have loaded some kind of beta library? it sounds as though the door/window macros you're using aren't as robust as the ones you've been using until this point.
alternatively, you've made some amendments to your doors/windows (like setting something to a zero width/length/height?) that the objects are disagreeing with . . .
~/archiben
b e n _ f r o s t
Jay,
The macro "wa_trim_us_10.gsm" is notorious and versions of it have been
since AC 8.1. There is an article about it on the Grafisoft US technical
resources site.
Peter Devlin
Peter wrote:
The macro "wa_trim_us_10.gsm" is notorious...
Yup, that little piece of code has caused me (and my clients) lots of headaches.
Peter wrote:
There is an article about it on the Grafisoft US technical resources site.
The only article I can find regarding "wa_trim_US" deals with a group operations error. Do you have a link I could follow?
Guess what? Today everything works fine. Temperature? Moon phase? Sun spots?
