‎2011-02-04
09:27 PM
- last edited on
‎2023-05-24
10:54 AM
by
Rubia Torres
‎2011-02-04 09:38 PM
‎2011-02-05 05:52 AM
‎2011-02-05 05:54 AM
‎2011-02-05 09:14 AM
‎2011-02-05 03:39 PM
another Moderator
‎2011-02-05 06:25 PM
‎2011-02-05 07:16 PM
rob2218 wrote:Yes... use the "calc" to get the size, then copy 4 more in a line... I could also make it distribute within itself, but I wanted flexibility...
Hi Duane,
thanks for your suggested panel GSM object.
I teid it and had a question.
I'm assuming that I'm to only place ONE panel and then copy them over 4 times correct? it's not like the door will make a 5 panel door.
I saw where you can get the "carcass" for the empty opening and that's neat. at least I can have an opening that does indeed have trim and jambs and all those parts I need.
I tried that "Kommerling" thing but it's impossible to figure out what the heck parameter you are adjusting.
Cant understand why there simply isn't an option for a 5 panel of whatever number of panels doors in Archicad.
‎2011-02-05 09:50 PM
‎2011-02-07 04:54 PM
