Need help in small change of zone stamp
Hello dear friends. I need to do small change in "Zone_Stamp_1 19". I tried to do it myself, but I could not.
If someone could help, will be great.
In the calculated area I need to remove unit and add custom text after value. See image.
Is that possible?
Dontknow
At 'Zone Selection Settings' and under 'Zone Stamp' you can edit your lines (make them empty or fill them). You can create an 'own text' line.
Under 'Own text' you can enter a prefix and text.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Thanks for answer!
About adding custom text to zone stamp I know. But I need custom text on the same row with Calculated area (to keep calculated area's numeric value on my row). By default Calculated area have custom prefix option ("CA:" is the default prefix), I need something like custom suffix to calculated area, instead of unit.
I think I have to edit Zone Stamp scripts by opening it as object, but I don't know what to change. Maybe that is not possible at all, I don't know.
