We have recently upgraded the Mac we use as a file server and everything is working swimmingly EXCEPT- In the library manager window, the Server HD drive appears, but the library manager can't/won't navigate deeper into individual folders.
Consequently all our shared libraries and project libraries are "invisible" unless copied to the local machine.
All the file loading/hotlink/xref etc dialogs work normally - eg you can navigate to a server folder to open a .pln file in the "Open file" window, but can't get to the same place in the "library manager".
On starting, ArchiCAD 10 seems to take a long long time to boot- I think it is looking for a network location that doesn't exist to load a library.
I suspect either a path or a setting in ArchiCAD 10 has been affected by the server upgrade. But how to reset it?
AC9 seems unaffected, but AC11 has the same difficulty. Doing a Repair install of ArchiCAD10 didn't work either, but I don't want to do a complete reinstall on all the machines just yet.
Help! Any ideas would be appreciated.
PS: The "Server" is a G4 running OSX 10.3.5, the workstations are various G5's running from OSX 10.4.6 to 10.4.0.
