New Object 3DMD Polyline Fence
Mario Sacco
Hi
I'm working on a new object I will share with you on Archicad BimComponents. I share here it in the first beta version, so we can try to find some bags or improvements.
The object fence is really only a simple version of a main object most complex. The logic in which the main object works is to generate a 3d editable poly line, base to generate more complex or simple tubes along it, in which I can distribute more simple or complex posts.
I'll will use the main complex object to create single simple objects.
Give me any suggestion and request of any object based on this logic. I will be happy to try to create your personal request.
The last version is here:
https://www.dropbox.com/sh/jjef9nuhpfwh29y/AAAoBmgIsM-p6eHUy_thILn2a?dl=0
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
79 REPLIES 79
Mario Sacco
Example of 3DMD Polyline Fence
Mario Sacco
Mario Sacco
Mario Sacco
Mario Sacco
Mario Sacco
Mario Sacco
Example of the main Object (not attached)
Mario Sacco
Mario Sacco
I'm working on other setting, to have more flexibility on elevation.
