New Object 3DMD Polyline Fence
Mario Sacco
Hi
I'm working on a new object I will share with you on Archicad BimComponents. I share here it in the first beta version, so we can try to find some bags or improvements.
The object fence is really only a simple version of a main object most complex. The logic in which the main object works is to generate a 3d editable poly line, base to generate more complex or simple tubes along it, in which I can distribute more simple or complex posts.
I'll will use the main complex object to create single simple objects.
Give me any suggestion and request of any object based on this logic. I will be happy to try to create your personal request.
The last version is here:
https://www.dropbox.com/sh/jjef9nuhpfwh29y/AAAoBmgIsM-p6eHUy_thILn2a?dl=0
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
79 REPLIES 79
Mario Sacco
The last version, always in test, is ready.
Improvement:
- Bag solved
- Arc vertical editable with tangent in 3d o section
- Circular post
- Post alignment
- Real sill thikness
- Foundations
Follow images and the object attached.
Let me know if using it you find bags.
Mario Sacco
Image of a combination.
Mario Sacco
Image of a combination with circular post and foundations
Mario Sacco
Image of a combination. Create your personal ramp using the sill with real thickness.
Mario Sacco
Mario Sacco
Tools.
Mario Sacco
The new object zipped.
https://www.dropbox.com/s/jlgaqs2e3y4ak0w/3DMD%20Polyline%20Fence.zip?dl=0
Hmooslechner
New version with fewer "bugs" and nearls prof. usable now..
german Vid but easy to understand..
https://www.youtube.com/watch?v=a2p9plEdRCg&feature=youtu.be
download AC18Edu-Aut file:
https://www.dropbox.com/s/jqs9im2dv7c1swh/Eigener%20Polygonzug_j.pln?dl=0
Mario Sacco
Here the code of the object of the single editable polyline.
It's free for use.
Mario Sacco
A 3d image of the object 3DMD Polyline.
