Mario Sacco
New Object 3DMD Polyline Pathway
I made this new object, based on the same macro used for 3DMD Polyline Fence.
http://archicad-talk.graphisoft.com/viewtopic.php?p=232856#232856
A 3d editable poly-line. The texture follow the path.
It's in beta test. I'm still working on many bags and enhancements.
Let me know if you have questions.
I hope it will useful for your works.
The link for the download is here:
https://www.dropbox.com/sh/86y9z3intan2lq3/AACdWNuzn503ZL-jjikiM9q-a?dl=0
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
28 Replies 28
BTW there's an error regarding BIM Componenets - the filenames get "www like" coding eg space gets %20 inside the filename instead of pure space.
I am not sure if it is Fx error or in general.
Best Regards,
Piotr
Mario Sacco
Best Regards,
Piotr
It works to me. Let me know.
Mario
I have also downloaded this LCF file and the file name correctly contains SPACE character, no problem with it on my computer.
I have English Win7 on my computer, for what it is worth.
Piotr, do you have English or Polish Windows?
(You might want to put your computer specs in your signature in your Profile page)
Mario Sacco
New Update for the object with improvements:
crossings and branches
Here the video:
http://youtu.be/82QLWLl_cb8
Here to download:
http://3dmediadesign.blogspot.it/
I use EN Windows, I did not check from IE only from Firefox from which all spaces from BIMComponents get www coding (all lcfs I ever downloaded this way). The enclosed snip shows the problem.
Best Regards,
Piotr
Katalin Borszeki
Hi Pjotr, along with Laszlo, I believe the problem might be with your Windows language settings! Is your windows EN? the space character seems not to be supported in your system. Thanks, kata
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
The problem is Firefox only - on IE the files with spaces in the names are saved correctly.
Yes I use ENG windows withe local settings set to Polish. Firefox is also ENG
So if the problem is on Firefox only so I believe there is a glitch in page coding not in the clients' systems
Best Regards,
Piotr
Mario Sacco
Some Bugs solved
Here a new video:
http://youtu.be/-6ZJLOWVyKg
Here to download:
Mario Sacco
3DMD Polyline Pathway 4.0 - New update
Bugs solved, toler resolution option and constant thickness
http://www.3dmediadesign.it
