Jan2
No objects found
I downloaded archicad and was now trying to place a few trees on a map (I don't know the English term). The problem is, when I compared it with my co-students, it turned out they had all kinds of tree pre sets and other objects and in my case, none of them seem to have downloaded. Should I redownload the whole thing? Or can I individually download the objects?
1 Reply 1
Guru
File => Libraries & Objects => Library Manager
Check to see if you have loaded all of the same libraries. If not you may be able to manually Add them if they are default or shared libraries. Also ensure that you are running the same localisation of AC as your classmates.
Ling.
