Non visible label "tail"?
I've created a simple GDL label for displaying the SLAB_TOP_SURF -value of a slab. Is there a way to make the marker "tail" (the line with the arrowhead at the end) disappear, so that the only visible part of the label would be the text?
The workaround for now is to set the 'tail' line color to white.
3 Replies 3
Hi Samppa,
You could try some "Sampling" of the "Slab Label 12"...
It has a check box where you can control the arrow/line visibility.
Save it with another name and do all your modifications on it.
HTH.
Wow. Now that's simple.
And to think that I never knew that checkbox existed. Thanks!
You´re welcome Samppa.
