Find the perfect object, manage libraries, create custom objects
Not able to change color og table in 2d
I have used some objects showing very nice tables in 3d.
But when I try to make it look better in floorplan (2d), then the tabletop
is violet. It doesn't seem to matter whatever I try. Here is a screendump of the parameters I guess is the most proper in this situation.
Are there somthing else that matters? Or, is it as I guess, something wrong with this spesific object? Is it still possible to correct it in the 2d script, for instance. But what should I look for?
1 REPLY 1
I solved the problem. In the 2d script there was a POLY2_B statemant. At the fill 'background pen' parameter position, I found the constant 91.
I replaced it with the fill_pen variable, and voila: It helped.
