Calculated field in Zone Stamp
Hi
I'm trying to cook up a fancy zone stamp and as part of it I've calculated a field which shows successfully in the stamp in plan view. However, it isn't coming through to a schedule. Is there a way I can feed back my calculated value to the stamp so it will show in schedule?
TIA
Adri
You have to have such parameter set up and via PARAMETER function You should fill this parameter up (preferably in parameter script or master script).
Best Regards,
Piotr
