2025-11-04
07:26 PM
2025-11-05
08:39 PM
HI, is there a posibility that object doors can be open in 3D? for kichen objects and others
Operating system used: Mac Intel-based 14 sonoma
Solved! Go to Solution.
2025-11-05 01:53 AM
Not with the Graphisoft kitchen cabinets,
They can only show the door swings in 2D.
Other objects?
You would have to be more specific as to which ones.
2025-11-05 01:53 AM
Other objects?
2025-11-05 12:13 PM
other objects like a closet or wardrobe
2025-11-05 12:57 PM
I think you will find most other cabinet objects will be the same - no opening in 3D.
However in version 27 (and before) libraries there is a door object call "Built-in Wardrobe".
This has opening doors in 3D just like other doors.
So you use the door tool and place it in a wall, but it will also add the cabinet.
