ā2025-11-04
07:26 PM
ā2025-11-05
08:39 PM
HI, is there a posibility that object doors can be open in 3D? for kichen objects and others
Operating system used: Mac Intel-based 14 sonoma
Solved! Go to Solution.
ā2025-11-05 01:53 AM
Not with the Graphisoft kitchen cabinets,
They can only show the door swings in 2D.
Other objects?
You would have to be more specific as to which ones.
Other objects?
ā2025-11-05 12:13 PM
other objects like a closet or wardrobe
ā2025-11-05 12:57 PM
I think you will find most other cabinet objects will be the same - no opening in 3D.
However in version 27 (and before) libraries there is a door object call "Built-in Wardrobe".
This has opening doors in 3D just like other doors.
So you use the door tool and place it in a wall, but it will also add the cabinet.
