Object visibility
Johann_P
I seem to have encountered a object visibility setting that I cant find.
Some chairs are visible above the table, but others are not visible above the table.
But all the settings of the chairs are the same.
Even the "Pick up / inject parameters" does not change this.
What am I doing wrong?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
You need to use 'Display Order'.
As they are all objects, they will appear in the same display level, so those placed last will appear on top of any other objects (regardless of their height).
gedzior84
Yes, I think that these key combinations would be your best friends for this problem:
CTRL + 4
CTRL + 5
CTRL + 6
CTRL + 7
