‎2018-02-20
10:11 AM
‎2025-08-06
05:04 PM
Aruzhan Ilaikova
‎2018-02-20 01:54 PM
‎2018-02-20 03:06 PM
‎2018-02-20 03:12 PM
‎2018-02-21 02:24 PM
izakwhite wrote:Don't reinstall ArchiCAD! If you are using "projected with overhead" then you will need to pay attention to the Floor Plan Cut Plane; using Symbolic ignores the FPCP so is simpler to use.
Thanks David, the renovation filter etc. was good. I changed the display to projected with overhead.
i simply can't understand why the fact that i make a small offset can change where the wall is located! I'm inclined to delete Ac and reinstall!
