Objects not appearing in views
Hi, I seem to be struggling to see some objects on views other than a plan. see attached extracts. Ive placed a tap fitment on plan above a basin. The basin appears in both the 3d view and elevation, but not the tap.
2 Replies 2
Check your Model View Options (MVO) for general objects associated to these views.
Probably the "Show Taps" option is disabled.
Hope this helps.
Lingwisyer
Guru
They are elevated properly? Custom object origin might be squiffy resulting in the ZZYZX not actually being the elevation to the centre of the object. Select the two objects in 2D then just view those.
Ling.
