Objects not to correct size in Arch 22
When adding kitchen units, cupboards, etc, the objects appear at incorrect sizes. Sometimes they have almost no thickness and usually they are too small. I have to select them and then add the correct dimensions in settings.
This only started a couple of months ago. Before that it was fine
12 REPLIES 12
DGSketcher
Legend
Somebody is up late! Beat me too it.
Barry is referring to the tool bar at the top of the screen in the default UK template set up. In AC there is a bit of a quirk where some settings don't appear in the main tool setting dialog, this is one of them. I have attached a snapshot to help you locate the icons.
No, but it is now beer o'clock on a Friday afternoon here down-under (west side), so I am signing off for now.
Barry, thank you so much. That's sorted it. This has been driving me nuts
Ian
