Objects saved from 3D window will not load
I have created several objects in AC10, also tried in 8.1 and they will not load. If I try to load them with the dialog box they are "greyed" out and cannot be selected. The first two I made loaded fine, I then tried to rotate one and save it in a different angle from the 3D window and since then no objects created can be loaded.
Any clues?? I'm completely baffled.....
1 Reply 1
Well, I answered my own question!! I'll leave it here for anyone else who might have this issue.
My default sub-catagory was set to wall/door. I opened each new object and changed the sub-catagory to something other than wall or door - in this case Theatrical Stage Equipment. Once I did this, now I can load the objects!!
