Wilz90
Opening lines on cabinets not showing
HI
I'm using ArchiCAD28 and I cannot get the opening lines on the cabinets (base cabinet block 27)  to show up in 2D or 3D, I've googled the issues but can seam to find a solution, can someone please help me?
2 Replies 2
Lingwisyer
Guru
So you have checked your MVO? Though, is there a reason you are using the AC27 / AC 28 Monolithic library? Either way, I would assume it is the same.
Ling.
ps. I do not utilize the opening lines on these objects and instead use my own object to show openings and annotate them...
Wilz90
I have worked it out now, I had to removed and reload the ArchiCAD 27 library objects, I can now turn the cabinet lines on.
Thanks anyway.
