2025-03-28 02:38 AM
HI
I'm using ArchiCAD28 and I cannot get the opening lines on the cabinets (base cabinet block 27) to show up in 2D or 3D, I've googled the issues but can seam to find a solution, can someone please help me?
2025-03-28
04:32 AM
- last edited on
2025-03-29
12:36 PM
by
So you have checked your MVO? Though, is there a reason you are using the AC27 / AC 28 Monolithic library? Either way, I would assume it is the same.
Ling.
ps. I do not utilize the opening lines on these objects and instead use my own object to show openings and annotate them...
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2025-03-28 04:37 AM
I have worked it out now, I had to removed and reload the ArchiCAD 27 library objects, I can now turn the cabinet lines on.
Thanks anyway.
