Outputting to a txt. file
I'm nearly finished building my GDL object, and to finish it off I want to output information about the object to a txt. file eg: length, description of individual parts in the object, their quantity, so i can send this to Access to work out a final price of the job. The script works fine for one GDL object but if I add another one the initial information sent to the txt file is overwritten by the next object.
How do I rescript it so that this wont happen, at the minute I am exporting individual files to Access when instead it would be easier and quicker to just send 1.
This is part my script:
Executive script:
IF outdat THEN GOSUB 900: !File I/O
END
900: ! File OUTPUT Routine
!Write Costings Access Report File
ch1= OPEN("TEXT", acost+".txt","SEPARATOR='\t',MODE=WO")
OUTPUT ch1, 1,0, "Description","Qty","Length","Type","Qty per Length","Cost/Unit","Cost","Weight (kg/m)","Weight/Unit (kg)","Total Weight (kg)"
OUTPUT ch1, 1,0, "Ball",nosections," ",ball*1000," ",F1,F1*(nosections),spherew,spherew,spherew*nosections
Close ch1
In parameters I tpye in the what name I want to call the file and this is related to: acost
MODE = WO overwrites the existing file
MODE = WA appends to the existing file
There may be quite a bit more to get this to work for you though, depending on just precisely what you want to do. Clearly you don't want to keep appending more and more data forever. The simplest thing might be to set the database to clear the contents when it reads the file.
Managing data through intermediary text files can be troublesome though. You might do better to use the interactive scheduler to extract the data for you.
