PIPG, VECT, VERT, EDGE
I wonder if any of you have ever used these commands, specially PIPG, which would help me to get rid of the contour lines of the Tree Bitmap object with the openGL engine.
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Frank Beister
Yes, I have. It is raw programing, but it works. If you can read a bit German or automatically translated text you could give it a try on selfGDL. You find some examples over there too.
Thanks!
Nando Mogollon
