Find the perfect object, manage libraries, create custom objects
PROBLEMS BETWEEN CURTAIN WALL. WALL AND DOOR
I WANT TO PUT THESE THREE THINGS TOGETHER(AS PICTURE SHOWN), HOWEVER, THE 3D COMES TOGETHER LIKE A MESS, AND I WANT TO DELETE THE FRAME OF THE CURTAIN WALL, BUT I CAN'T.
HOW CAN I DO IT?
THANKS FOR YOUR HELP.
5 REPLIES 5
Dwight
Since the Curtain Wall tool has changed a lot in Archicad 12, you will get better advice if you ALWAYS add your Archicad Version Number and Computer Equipment Spec in your signature.
Dwight Atkinson
here is my profile
You can set any Frame of a Curtain Wall to Invisible. It is found in the Type field.
for the ground floor
previously, i build a short wall > then place curtain wall> then place door
this time,
place a full height wall> add the door > build curtain wall in each side of door > use window opening to make the wall shorter.
now i can do it!!!!
thx dude!!!
Looks good.
