ā2005-11-23 11:27 AM
ā2005-11-23 11:28 AM
ā2005-11-24 10:26 AM
ā2005-11-24 10:28 AM
add 0,0,0.8 ! !!! define a new material parameter "matcpl" in parameter list material matcpl !!! this material will be used for the resulting surface CUTPLANE DEL 1 if matT="Symbol" then material SYMB_MAT else material "mat2D" ROTX 45 ROTY 45 BLOCK 1,1,1 DEL 2 CUTENDyou will see this effect not only on the 2d-komplete view but also in the 3d view, if the 3d surface fill effect is "on" i 3d window settings.
ā2005-11-24 03:47 PM
but in the 2D view there is a "brick" fill on the section area I don't know, where it's from
