Parameter "height" in the plan
mest79
Hi!
I have a object gdl and I want to indicate in plan what height the object is placed on.
I want to visualize the parameter "base height" in the plan.
Thanks
Architect
AC22 (3006) - i7-6820HQ, 16Gb, AMD FirePRO W5130, WIN10
7 REPLIES 7
If it is your own object and you can program in GDL then you could adjust the script to show text for the elevation.
Otherwise add a label.
There is an 'elevation label' that should do what you want.
mest79
Barry,
I created the object myself. The object is very simple and I can program in GDL, but I don'd know how to edit the GDL to create a "label" already inserted in the object.
Thanks!
Architect
You don't need to script a label, just add some text with the symbol height.
TEXT2 0,0, SYMB_POS_Z
You will need to add a Boolean switch and an IF/THEN statement if you want to turn the text on and off.
Or you can just as a label with the label tool to each instance of the object in your plan - which you can turn on or off as needed.
mest79
Perfect!!!
Thank you Barry!
Architect
mest79
Is it possible to add decimals?
Now the text2 shows "3" (3 meters) and I prefer "3.00"
Thanks!
Architect
You will need to use the STR function.
probably something like ...
TEXT2 0, 0, STR("%0.2m", SYMB_POS_Z)
mest79
Thanks!!!
Architect
