Parametric cut fills in a Library Part
Daniel Lindahl
Is it possible to script what cut fills / building materials to use for various parts of a Library Part? I would like to assign different cut fills within the one object.
However I can't seem to find a GDL syntax for this.
cheers
Daniel
Daniel Lindahl Architecture
AC24 | Dell Inspiron 16+ | Windows 11
You will be wanting to use SECT_FILL every time you want to change the fill.
You can't use Building Materials in objects so you can only specify the section fill.
You may need to ensure you use MODEL SOLID as well otherwise you will have hollow elements.
Daniel Lindahl
Thanks Barry,
that worked a treat! Don't know how I missed that in all my years of scripting!
cheers
Daniel
