2013-09-21 04:49 PM
2013-09-21 04:52 PM
2013-09-21 04:53 PM
2013-09-23 07:14 PM
2013-09-24 05:40 AM
2013-09-24 05:28 PM
2014-10-22 09:22 AM
2014-11-11 09:32 AM
2014-11-11 06:33 PM
2014-11-12 05:36 AM
sinceV6 wrote:Thanks for your reply.
Hi!
Well... the answer is yes, itispossible (and quite time consuming to script it correctly); but are you talking about adding it as 3D geometry? It would create a lot (and I mean a lot) of polygons for AC to handle, and I think the option falls out of the BIM scope of things.
For 2D representation, you can create the fill of your pattern and use that in the object's options (parking space background fill). For 3D, it would be better to use a texture. If you are asking because you need it for rendering, a texture (with displacement) should work, and if you want a closeup, repeat the object you made in a small area close to the camera.
Best regards.
