Path to duplicates
I'm having an issue with lots (couple thousand) of duplicates in a library, I did not create just arrived and trying to get a grip on things! Is there a way to see the path of the duplicates? I think most of the time they aren't even objects but textures.
Thanks
4 REPLIES 4
With so many this is usually a problem of duplicated libraries. Like loading the full libraries from different versions.
Unfortunatly not, it's objects that had been added to the library over time!
Up to 14 versions of the way to duplicate the output to a report library loading
Now this can be done through a special menu if the OS windows need to edit the registry 0 to 1. (on a Mac I do not know) Then adjust the work environment - check libraries.
I found the problem, some objects have the sam GUID but different names on the file itself, how can I search for duplicate GUID's? Thanks
