SeaGeoff
Ace
Pen chart object?
I'm imagining a utility object that will automatically build a pen chart in the floor plan window with a user defined array of squares and accompanying text label for each pen. It would be a great help when introducing new coworkers to our pen standards. Any of you GDL master have anything like this you'd be willing to share?
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
8 Replies 8
I just found something close on objectsonline that is close, Geoff. (Searching there is a b**ch, as quotes, "and", and "or" mean nothing ... but found it in the 'utilities' group.)
Swatchmaker:
http://www.objectsonline.com/arc/Detail.tpl?DB_Title=Swatch%20Maker&DB_SKU=A00613
Not quite what you want, as it doesn't display pen weights, and seems spendy for just displaying colors. Actually, scanning the GDL manual, it doesn't appear that GDL can retrieve pen weights, only their RGB color values, so your wish might have to be done by an add-on using the API.
If just a list is OK, then SQL should be able to do the trick...I'll try that and post back.
SeaGeoff
Ace
You can get a list straight from Attribute Manager, but that's not much use in explaining the logic of a pen set-up. I was definitely thinking of something graphical. I started doing it manually, with fills and attached labels, typing the pen number inot the ID field one at a time. Not a big deal, but it would be so cool if the whole thing was automatic.
It is a shame that GDL can't return pen weights, and that should be remedied.
Thanks for the tip about Swatchmaker, and thanks for you seemingly endless capacity to help gomers like me.
Dwight
There is an easy way to do this without GDL:
Make a chart with all of your standards and label them with a short explanation for newbees.
Paste this chart into a GDL Object 2D symbol window and save as, say, "Drafting Standards."
Place the object into a new project - perhaps into the fake section window where many power users store miscellaneous stuff - and explode it.
All of the element types will become active and can be cloned to guide new work.
Dwight Atkinson
Dwight
This approach emulates the MSA detailer where clever use of fake sections led the way years ago, creating the "sideshelf" assisting the rigid ArchiCAD plan window.
Dwight Atkinson
Dwight's suggestion is perfect if pen weights are not required (or if they are fixed by standard, and you don't mind typing them in ... I don't like having things like that 'static' anymore than I like unlinked model data).
Here's a way to get the info using the SQL option in the Calculate menu. If you do not see SQL in Calc, then go to Preferences, Imaging & Calc to set Calc Menu appearance to "Full with SQL".
Enter the simple query "select * from pens", and the result will appear in your browser similar to the screenshot below...
[continued in next post]
PS Ah, you're right Geoff. This might be overkill, since saving from Attribute Manager gives the same information ... as well as an indication of which pens are 'in use'. That text file can also be opened in Excel (next post).
[part 2 of 3]
You can copy and paste the result data directly into Excel - info will go directly into columns properly as shown in the attached screenshot.
The attached shows the result of a small VBA routine - the final post will include the actual spreadsheet with this button and function - that colors the cells with the actual RBG of the associated pen.
One could write slightly more complicated VBA that instead produces an ordered, labeled, colored pen table from the data in a new sheet.
I prefer this SQL/Excel solution since it guarantees that the data exactly matches what is in the actual pen table in ArchiCAD ... no opportunity to screw up the weights. (A better-integrated solution, actually, is to do it in Access with the PLN ODBC driver ... then the Access can directly query the PLN and produce the colored table without additional intervention. Only works on Windows though.)
[part 3 of 3]
Finally, attached is the Excel spreadsheet that includes the coloring function. Just paste your SQL output into the sheet, being sure to copy the title row and to paste into cell A1. Then click the button to color things.
The code for the colorizing is:
    nRow = 2 ' skip heading row
    While Cells(nRow, 1).Value <> ""
        Range(Cells(nRow, 2), Cells(nRow, 4)).Select
        Selection.Interior.Color = _
            RGB(Cells(nRow, 2), Cells(nRow, 3), Cells(nRow, 4))
        nRow = nRow + 1
    Wend
    Cells(1, 1).Select ' jump back to top of sheet
Dwight
Wow.
I never considered that newbees could mess with the lineweights in a template, but it could happen.
I have obviously misunderstood the compexity of this issue - I thought this was about making a simple explanation of basic lines [and perhaps fills] to persons new to a project.....
Duh.
Dwight Atkinson
