Pen is less than 1
JGoode
Just something I am curious about and isn't that big of a deal but why do pens allow you to set them as transparent or 0 or -1 but then throw up an error saying that the pen is at less than 1?
ArchiCAD 27
Windows 10
Erwin Edel
Background pens can have this value. That is why you can set it as a parameter.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Erwin Edel
www.leloup.nl
JGoode
Makes sense! Thanks
ArchiCAD 27
Windows 10
runxel
Hero
That's why you have to make sure that foreground pens can't be set to anything "unhealthy":
! param script
if certain_pen < 1 then
    parameters certain_pen = 1
endif
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
