Display malfunction of Graphisoft ID dashboard
Learn more
JGoode
Picture2 Display Order
Hello,
I'm trying to add a picture in 2D but it defaults to be behind my fill - I have tried using DRAWINDEX but that doesn't seem to work either. Is there just no way of bringing a picture in front of a fill?
Here's my code for reference:
DRAWINDEX 10
add2 symb_pos_x, symb_pos_y
ROT2 symb_rot
if dis_symbol then
	if (type = t1) then ! Outlet
		if (sign_type = st1) then !dry
			picture2 "dry_riser_outlet", symb_height, symb_height, 1
		else
			picture2 "wet_riser_outlet", symb_height, symb_height, 1
		endif
	else
			picture2 "dry_riser_inlet", symb_height, symb_height, 1
		else
			picture2 "wet_riser_inlet", symb_height, symb_height, 1
		endif
	endif
endif
DEL 2
DRAWINDEX 30
pen gs_fill_pen
project2{3} 3, 270, 3 + 32, 4, gs_back_pen  ! adds fill
pen gs_cont_pen
project2 3, 270, 2 !adds outline
ArchiCAD 27
Windows 10
1 Solution
I can’t test your script at the moment, but just looking at it you need DRAWINDEX 30 for the picture then DRAWINDEX 10 for the fill.
Or try scripting the fill first and then the picture (I am not sure if that will change anything but try anyway).
Go to post
3 Replies 3
And looking at the script again you are not adding a fill.
You are using PROJECT2, so maybe that is the problem and it can’t go behind - I have never tested this.
JGoode
Thanks for your help Barry, I must have misread the gdl guidance.
Just to confirm - it doesn't work with the PROJECT2.
ArchiCAD 27
Windows 10
