‎2009-03-05
10:42 PM
‎2023-05-24
12:40 PM
Rubia Torres
‎2009-03-05 11:59 PM
‎2009-03-06 12:19 AM
‎2009-03-06 12:22 AM
‎2009-03-06 12:44 AM
How do I change my rank?
In general you cannot directly change the wording of any rank (ranks appear below your username in topics and on your profile depending on the style used). Most boards use ranks to indicate the number of posts you have made and to identify certain users. For example, moderators and administrators may have a special rank. Please do not abuse the board by posting unnecessarily just to increase your rank -- you will probably find the moderator or administrator will simply lower your post count.
‎2009-03-06 12:22 PM
carmen83353 wrote:If you have a couple of post, you automatically become New Member instead of Guest. You now have 5 so you are fine.
hey Doug,
This is going to sound dumb , but .. do you know why I appear to be as a guest and you as an active member? ( I joined last year but is the first time i actually post anything).
‎2009-03-06 02:32 PM
carmen83353 wrote:Carmen:
I did saved it as a window!.. but on 3d view the wall has a hole and the window is just touching the wall!!( in a 2x6 wall the window is 5 1/2 inches off)
‎2009-03-06 10:57 PM
the problem is when I place the window on the wall it looks good on floor plan but in 3d view the window is outside the wall..Carmen,
‎2009-03-06 11:17 PM
‎2009-03-06 11:58 PM
