Pls help - 'Curtain wall' type door with sidelight problem!
Heeelp!
The door is out of the standard library, curtain wall type (see attached image grabbed from library) and I want it to have ONLY ONE sidelight, an option that IS actually available for this door and i've used it in the past (v9) with no issues. Now it does this (see 2nd image).
What's happening? How can I solve it?? I really need this to work as it's supposed to.
5 Replies 5
ok, can't attache 2 images to 1 post!
so here the second image sowing what it's doing when i place is in a wall.
Unfortunately the curtain wall parts are bug ridden. Not much you can do until Graphisoft release a library update.
Graphisoft's quality control of their library parts in Archicad 10 is abysmal.
:breathes sigh of dissapointment and frustration:
Did it ever worked? NO
And even if it did one could not add a vertical mullions, only one sidelight. This is not curtain wall is a bud ridden door.
For all to know!!! Graphisoft newer had a curtain-wall with a door in it.
workaround, save a v9 project as a .pla (archive) and nick the library parts ie curtain wall doors for use in v10.
...so far so good.
