Pop up window
Is it possible to add certain code to the script of an object that creates a pop window? (similar to the msgbox command in Excel VBA) A warning box for example that let's the user know that a certain condition has not been met. It could be closed with an OK button and be functional in all environments. (plan, section, elevation etc.)
Thanks,
Doug
David Maudlin
Doug:
The closest command I know of is PRINT, see page 292 of the AC 19 GDL Reference Guide.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David, I'll look into it.
Doug
