Problem with Doors and Window library parts in Archicad 22
I am inserting a french door with a glass pane and the door is solid. Everything looks fine in the preview but the 3d object does not look like the preview. Similar issue with windows.
2 Replies 2
Check your Model View Options.
3D for doors and windows can be set to simple or detailed - sounds like your settings may be simple.
Lingwisyer
Guru
Quite a few people are running into this. I think that in the AC22 template, the MVO is set to Simple by default...
Ling.
