Problem with IES light object
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-12-07 05:59 PM
2015-12-07
05:59 PM
As far as I understand, the IES object is able to pick up the luminous size of a IES file (if included within the file itself) and is able to generate an illuminated shape to represent these dimensions. This is of particular importance when using IES files to represent fluorescent fittings/strip lighting, as the IES profile must be "stretched" accordingly.
I am currently using an IES file from Fagerhult (
This doesn't cause a problem for point/circular lights, but for rectangular fittings I can't use the IES object to realistically represent the fitting being used.
I spoke to Graphisoft support and was told that the file I am using doesn't have parametric sizes in it, but I have checked and this isn't the case. Almost all of the IES files I've looked at do have sizes in them, but Archicad doesn't seem to be picking this up.
Help?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-07 06:55 PM
2015-12-07
06:55 PM
i thought an IES profile was actually for a lightbulb, not a specific fixture. Did I miss something?
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
Rhino 8 Mac
MacOS 15.2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-07 07:29 PM
2015-12-07
07:29 PM
Aaron wrote:I suppose so, as far as I understand IES profiles are to provide the illumination profile for a specific fixture. As it currently stands, it's fine using the IES object for emulating point/spot lights, but in the case of longer fixtures. it's not possible. The IES object alludes to being able to use the sizes provided in the IES file but doesn't seem to want to. In the video from Graphisoft (
Does that clarify the issue?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-08 04:34 PM
2015-12-08
04:34 PM
I thought I'd add some extra information.
Attached is a screenshot of the settings as I have them in Archicad.
So I am expecting the glowing shape to be the size as defined in the IES file. Now, according to the IES standard (Section 5.10)
So looking in my IES file, in the corresponding line, I have:
Output is as in attachment on the first message.
I guess I'm asking if anyone has ever managed to get this feature to work.
It does go on to say it's not inteded for renderings, but there are no other dimensions in the standard, so I am assuming this is where Archicad is supposed to be getting sizes from.Luminous Dimensions
The following dimensions refer to the luminous (that is, light emitting) opening of the luminaire, not its physical dimensions. They are meant to approximate the luminous opening (either as a luminous area or volume) for lighting calculations.
IESNA:LM-63-1995Indicating units in metres (2) and a width (1.44), depth (0.08) and height (0.00).
[TEST]
[MANUFAC] Fagerhult
[LUMCAT] 28829
[LUMINAIRE] DTI type 2 Beta 1x49W
[LAMP] 49W
[DATE] 2007-11-12 17:08:31
[OTHER] EULUMDAT file: 28829.LDT
TILT=NONE
1 4300.0 4.300 95 19 1 2 1.44 0.08 0.00
