Problem with arraytype parameters
In a object (auto_dim_a), we have a parameter (ovlp_coords) which is 50X2 Arraytype of APIParT_Length type. We used to have in over master script
ovlp_coords[1][1] = 0.00 : ovlp_coords[1][2] = 0.00
ovlp_coords[2][1] = 1.00 : ovlp_coords[2][2] = 0.00
ovlp_coords[3][1] = 1.00 : ovlp_coords[3][2] = 1.00
ovlp_coords[4][1] = 0.00 : ovlp_coords[4][2] = 1.00
ovlp_coords[5][1] = 0.00 : ovlp_coords[5][2] = 0.00
no_ovlpcoords = 5
parameters no_ovlpcoords = no_ovlpcoords
parameters ovlpcoords = ovlpcoords
now we changed this parameters array size from 50X2 to 150X3 and our master script is changed to like this
ovlp_coords[1][1] = 0.00 : ovlp_coords[1][2] = 0.00 : ovlp_coords[1][3] = 0.00
ovlp_coords[2][1] = 1.00 : ovlp_coords[2][2] = 0.00 : ovlp_coords[2][3] = 0.00
ovlp_coords[3][1] = 1.00 : ovlp_coords[3][2] = 1.00 : ovlp_coords[3][3] = 0.00
ovlp_coords[4][1] = 0.00 : ovlp_coords[4][2] = 1.00 : ovlp_coords[4][3] = 0.00
ovlp_coords[5][1] = 0.00 : ovlp_coords[5][2] = 0.00 : ovlp_coords[5][3] = 0.00
ovlp_coords[6][1] = 0.00 : ovlp_coords[6][2] = 0.00 : ovlp_coords[6][3] = 1.00
ovlp_coords[7][1] = 0.50 : ovlp_coords[7][2] = 0.00 : ovlp_coords[7][3] = 1.00
ovlp_coords[8][1] = 0.50 : ovlp_coords[8][2] = 0.50 : ovlp_coords[8][3] = 1.00
ovlp_coords[9][1] = 0.00 : ovlp_coords[9][2] = 0.500 : ovlp_coords[9][3] = 1.00
no_ovlpcoords = 10
if open a drawing which has this element and we are expecting array like this
0 0 0
1 0 0
1 1 0
0 1 0
0 0 0
0 0 1
0.5 0 1
0.5 0.5 1
0 0.5 1
0 0 1
but array was like this
0 0
0 1
0 0
1 1
0 0
1 0
0 0
0 0
0 1
0.5 0
1 0.5
0.5 1
0 0.5
1 0
0 1
if select that object and we click object selection settings and click OK then the array looks good.
Can any one have this type of problem?
Can any one give me suggestion to fix this problem please.
1 REPLY 1
You could declare array dimensions, and force "ovlp_coords" to update, with a "parameters" statement.
Is it what you are trying to achieve?
if bArrayTest then
	dim ovlp_coords[5][2]
	! your code
else
	dim ovlp_coords[10][3]
	! your code
endif
no_ovlpcoords = vardim1 (ovlp_coords)
parameters no_ovlpcoords = no_ovlpcoords,
			ovlp_coords   = ovlp_coords
Olivier
