Problem with the object's fill
Modeled lift car with the Morph tool, but when saved as object GSM plan view appears as "transparent or wireframe". I tried fix this in the settings file GSM 2D view, but for lack of knowledge in GDL failed. What can be done?
6 REPLIES 6
Eduardo Rolon
You can open the project and redraw the 2D symbol adding fills as necessary.
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
In the 2D Symbol window, fill is OK, but ...
... in the 2D View window shows the wireframe drawing. As I state a preference for the GSM file show 2D symbol and not a 2D view?
Eduardo Rolon
As far as I know the default should be the 2D Symbol View not the 2D View. Try saving the object from the 3D window instead or just watch this tutorial by shoegnome.
http://www.shoegnome.com/2013/05/30/creating-2d-symbols-for-archicad-objects/
AC29 US/INT -> AC08
another Moderator
David Maudlin
Judson:
If the object is using the 2D Script to generate the 2D view (take a look at the 2D Script and see if there is code there), then you can use the procedure outlined here to convert the scripted view to a drawn view for further editing:
2D symbol of Archibase.net objects
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David Maudlin and ejrolon for help. Could, explaining Shoegnome were targeted enforcement.
What I did: 1) I deleted the code window Script 2D / 2) 2D Symbol window we unified all fills equal / 3) And finally, trimmed some unnecessary lines
Not so hard. Again, thank you.
