Problems with 3D scripting prism_
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2014-12-25 09:03 PM
2014-12-25
09:03 PM
this is the code
1, 0, 15+64,
.5, .5, 915,
0, 180, 4015,
0, 0, 15,
1, 0, -1
This is a code that makes a curved line to the outside. the line i used was the diagonal line in the triangle. now the question is how can i make this so the line is curved to the inside
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-12-26 10:39 AM
2014-12-26
10:39 AM
Using a negative angle (-180) might help
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-12-26 01:26 PM
2014-12-26
01:26 PM
Juha wrote:I tried that but that isn't the solution
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-12-26 03:00 PM
2014-12-26
03:00 PM
jensvs:
The center of the arc (status code 915) needs to be moved out, the direction of the arc needs to be reversed (negative angle) and the angle should be 90˚, not 180˚. When working on these sorts of problems, it helps to draw the shape desired to work out the code.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
