Hey i'm a student and i'm having problems with creating a PRISM_ with curved lines. can you help me please
this is the code
1, 0, 15+64,
.5, .5, 915,
0, 180, 4015,
0, 0, 15,
1, 0, -1
This is a code that makes a curved line to the outside. the line i used was the diagonal line in the triangle. now the question is how can i make this so the line is curved to the inside
The center of the arc (status code 915) needs to be moved out, the direction of the arc needs to be reversed (negative angle) and the angle should be 90Ė, not 180Ė. When working on these sorts of problems, it helps to draw the shape desired to work out the code.
David
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC29 USA Perpetual ⢠Mac mini M4 Pro OSX15 | 64 gb ram ⢠MacBook Pro M3 Pro OSX14 | 36 gb ram
