Project2 for custom door plan
is there a trick to using PROJECT2 for custom doors? the projection code only shows front or side views of the door in the plan preview.
I want to create a projected and symbolic option for my custom door, but project2 just isn't working.
10 Replies 10
David Maudlin
patmay81 wrote:
I had tried PROJECT2 5, 0, 2... but not 90, that was my problem. I was not thinking of it as actually rotating the 3d view to an alternate plane, just around its own plane. 5, 90, 2 works great. 3, 270, 2 also works, not sure of the advantage of one over the other.
The 3, 270, 2 settings show the side of the door, not the top view here, not sure why it works for you. See my reply to DGSketcher.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
