ā2017-05-10
03:07 AM
ā2023-05-26
02:15 PM
Rubia Torres
ā2017-05-10 04:04 AM
ā2017-05-10 04:43 AM
ā2017-05-10 05:56 AM
benjamin_chan wrote:I am sure Rogerdodge means to set the floor plan display of the wall just as you did for the window.
Hi Rogerdodge
Thanks for the reply. I'm not following what you mean by "set the floor plan cutting plane on the wall" - can you clarify please?
Thanks,
Ben
ā2017-05-10 06:43 AM
ā2017-05-10 07:34 AM
Rogerdodge wrote:Was it the chart Laszlo did for this post?
Yes thats about what I meant.
While we are on the subject Barry, there is a good visual aid that explains the floor plan cut settings really well, but i cannot find it, do you know where it is?
ā2017-05-10 08:40 AM
ā2017-05-11 03:19 AM
Barry wrote:Sorry....still not following....what Floor Plan Display of the wall are you suggesting I set it to?benjamin_chan wrote:I am sure Rogerdodge means to set the floor plan display of the wall just as you did for the window.
Hi Rogerdodge
Thanks,
Ben
If it remains 'Symbolic' then the settings you make to the window will seem to have no effect.
ā2017-05-11 03:58 AM
ā2017-05-11 07:01 AM
Barry wrote:Hi Barry
Not sure if this will help at all.
Seems you have to have a "projected with overhead" wall, with an "overhead all" window and then in the window settings override the object line types.
