PsynOpenProfTube free
26 REPLIES 26
Aaron wrote:
Trying to have fun, but the v18 objects don't appear to work. I'e loaded them in a library and re-loaded library. Can't see them in the object dialog box. they are "objects" right?
i sent you an 18 pln. i dont have 18 installed so hopefully that one will work for you
jclewis
Very interesting - I'd like to have a look at it.
jcl
James C Lewis
AC 24 (Full)
Mac Pro (Late 2013) OS 10.13.5
more people were interested than i thought so i put a download link in the OP.
DGSketcher
Legend
Thanks for sharing! Could be a useful tool to have around.
sinceV6
vistasp wrote:
SenecaDesignLLC wrote:
sinceV6 wrote:
Hi.
That's some nice work. You've made some great examples of how to use the polyline code.
Best regards.
thanks, with out your inspiration i could never have accomplished it. its going to open so many doors
SinceV6, your polyline code has spawned some really awesome stuff. Thank you.
Thanks. I've seen the stuff . Didn't think much of it when I was scripting it, as it was merely a self-imposed challenge and learning exercise. I updated the script to a second version about a year ago. I should have it archived. Anyone interested?
Best regards.
Best regards.
Yes please!
alemanda
I want to add that this is a great tool, it's a must-to-have.
I think GS should embed into the program as a tool.
There's a lot of useful objects that could be based on the editable polyline.
THANKS
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
I have been watching your videos in youtube. Very interesting objects. Thanks for sharing this one.
Hmooslechner
I downloaded it just for a few minutes and had a short look at the code: Its simply an genius gem! Thank You for sharing! I will try my own ideas to realize with this code in the future free to everyone but only with the permission from You of course.
Until now i just workd with the former code from sinceV6 which was challenging enough for me then, but now with the implementing of arcs so easy - it will be a pleasure to gon one once again.
Some suggestions:
The arc - function should implement hotlines for tangential continuing.
First - a hotline-tangent should be unvisible to be reached in the acr editing - building-process.
Second: After an arc - a further unvisible hotline - tangent should help You find the new direction of the next segment. No need to use it but good if its there..
Then - did You think of changing the axis of the Arc?
Now the Arc is just functioning in the XY-Plane.
How about rotating the Arc-function into the XZ-Plane to make smooth pitch-change possible?
Some suggestions:
i like your suggestions. they should all be very easy to make happen if time stood still ha ha, all of that would be cool to have but i am out of coding time for the next 4 or 5 months
