2026-08-24 02:15 PM - last edited on 2026-08-25 03:48 AM by Barry Kelly
Hi there,
I want to make a custom railing, that I can see post in floor plan.
With tip for project 2, or fragment2 to make 2d posts it works and I can see;
BUT, why are they always in the foreground?..... I want to see, that the lines from the railing are in the foreground, an the posts 1 step behind.
Here the example, violet posts behind the horizontal lines..... its possible ?
2026-08-25 03:56 AM
There are no controls that I am aware of.
I have a rail where the bottom rail (the brick modelled as a rail) hides the top rail, which clearly should be seen as it is on top.
It is there as you can see when I select it.
Just the display order is wrong.
This was brought to Graphisoft's attention way back when railing were first included.
When I get the motivation, I will report it again.
